(Latest Release) WP77xx Firmware Release 15.1 Components
  • Apr 27, 2023
  • Version: 1
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 15.1 components and how to download it on your product.
WP77xx Firmware Release 15.1 combined image
SWI9X06Y_02.36.08.09 / 001.079_000
Modem Firmware (AT&T)
SWI9X06Y_02.36.06.00 / 001.067_005
SWI9X06Y_02.36.08.09 / 001.049_000
Modem Firmware (Telstra)
SWI9X06Y_02.36.08.02 / 001.061_001
Modem Firmware (Verizon)
SWI9X06Y_02.22.12.00 / 001.042_004
002.015
SWI9X06Y_03.00.13.00
21.05.0
21.05.0 Source
SWI9X06Y_03.00.13.00 Source
  2. Select the "Target Menu".
