Telemetry data collection requires the router to be properly installed and connected to the vehicle. For most applications, you must connect the router’s ignition line (white wire on the power connector) to the vehicle ignition, and connect the router to the vehicle bus as described in the RX55 Hardware User Guide.
Vehicle settings are a subset of telemetry. To collect vehicle ignition status and CAN bus data from the connected vehicle, configure:
| VIN FORMAT |
VIN FORMAT specifies how the router decodes the vehicle’s VIN (Vehicle Identification Number) to determine the vehicle’s Make, Model and Year for matching against configured proprietary message descriptors. The router can only decode VINs in North American format. This setting prevents false matches when the router is connected to a non-North American vehicle. When set to North American, the router decodes the VIN and matches the resulting Make, Model and Year against proprietary message descriptors to retrieve proprietary data points from the vehicle. When set to Other, the router does not decode or match the VIN. |
North American, Other | North American |
To view the status of your telemetry configuration, go to Status > Services > Telemetry.
J1939 and J1979 protocols are currently supported. J1979-2 is supported in Beta mode, as shown below. Semtech is investigating support for J1979-3 and VDV 238 protocols.
Features marked “Beta” are available for early evaluation. While functional, they may be refined based on field feedback before general release. Please send feedback to trialfeedback@sierrawireless.com
The complete telemetry data set can be sent to AirVantage allowing for the viewing of all Advanced Mobility Reports(AMR). For more information, see Enabling Reporting in AirLink OS.
| ENABLE | When enabled, the full telemetry data set is sent to AirVantage so that all Advanced Mobility Reports(AMR) can be viewed. Only displays when Telemetry is enabled. | On/Off | On |
| REPORT MODE |
Report that will be generated when the device powers off. Note: Only one report can be selected and in situations where there is an abrupt power disconnect a report may not be generated. |
| AT EVERY SAMPLE OF… |
Example 2: WAN Ready
Example 3: Ignition Status
Example 4: Primary WAN
Options are:
Options are:
| <RELATIONAL OPERATOR> |
Options are:
Example: LEVEL Trigger
Options are:
Options are:
Example : EDGE Trigger
If you define an EDGE trigger to generate a report when vehicle speed >= 55 KPH, then samples C and L would each generate a report. These samples represent the moments when the configured EDGE threshold for vehicle speed was true. (i.e. Sample B is < 55 KPH and Sample C is >= 55 KPH; Sample K is < 55 KPH and Sample L is >= 55 KPH).
N/A | N/A |
None |
| TOPIC |
6Q1099009902AC24/test {
“atp.ser” :
“t”: 1693258321.3640001,
“v” : “6Q1099009902AC24”
“ts” : 1693268920.464
0 |
ATP FORMAT |
Individual Timestamp |
| CONNECTION SECURITY |
None |
| ROOT CERTIFICATE |
N/A |
