Telemetry data collection requires the router to be properly installed and connected to the vehicle. For most applications, you must connect the router’s ignition line (white wire on the power connector) to the vehicle ignition, and connect the router to the vehicle bus as described in the XR60 Hardware User Guide.
| VEHICLE IGNITION STATUS | Current vehicle ignition status. Read only. | On/Off/Not Available | Not Available |
To view the status of your telemetry configuration, go to Status/Monitoring > Services > Telemetry.
J1939 and J1979 protocols are currently supported. Semtech is investigating support for J1979-2 and J1979-3 and VDV 238 protocols. AirLink OS can currently detect both J1979 and J1979-2, but as shown below, Telemetry status will indicate whether a protocol version is not supported.
The complete telemetry data set can be sent to AirVantage allowing for the viewing of all Advanced Mobility Reports (AMR). For more information, see Enabling Reporting in AirLink OS.
| REPORT MODE |
Report that will be generated when the device powers off. Note: Only one report can be selected, and in situations where there is an abrupt power disconnect a report may not be generated. |
| AT EVERY SAMPLE OF… |
Example 2: WAN Ready
Example 3: Ignition Status
Example 4: Primary WAN
Options are:
Options are:
| <RELATIONAL OPERATOR> |
Options are:
Options are:
Options are:
N/A | N/A |
None |
| TOPIC |
6Q1099009902AC24/test {
“atp.ser” :
“t”: 1693258321.3640001,
“v” : “6Q1099009902AC24”
“ts” : 1693268920.464
0 |
ATP FORMAT |
Individual Timestamp |
| CONNECTION SECURITY |
None |
| ROOT CERTIFICATE |
N/A |
