    AirLink routers are equipped with location tracking, enabling you to track the movements of a vehicle or other devices that move. The router relays the information of its location as well as other data for use with tracking applications.
    • Computer-Aided Dispatch/Automatic Vehicle Location (CAD/AVL): The router provides real-time location data to the server that tracks the location and other variables of the vehicle or asset.
    Hardware Requirements
    Ensure that a GNSS antenna is connected to the router. See the XR60 Hardware Guide for installation and antenna connection instructions. For compatible antennas sold by Semtech, see our website.
    After enabling GNSS with the antenna connected, check the GNSS LED to confirm GNSS operation. The GNSS LED will be red while searching for a fix. After getting a fix, it is green.
    For legacy applications that may require GPS-only, you can limit the location service by selecting the “GPS Only” option. See LOCATION CONSTELLATION below.
    Enabling Location
    To enable GNSS, go to Services > Location > General and click the switch under GNSS ENABLE.
    Router geolocation uses cellular or GNSS fix. If the router has no cellular connection and GNSS is disabled, the geolocation for the Wi-Fi will be “Unknown” and Wi-Fi will be restricted to 2.4 GHz channels only.
    GNSS status is reported under GNSS STATE, and can include the following status messages:
    • Starting
    • Device Unavailable
    • Waiting For New Fix
    • Location Fix Acquired
    • Firmware Upgrade in Progress
    • Firmware Upgrade Failed
    • Firmware Upgrade Successful
    Status messages related to Firmware are shown after you manually select new GNSS Firmware for the router to use, and when an AirLink OS firmware upgrade is in progress. See GNSS FIRMWARE SELECTION MODE below.
    GNSS CURRENT FIRMWARE Current version of firmware on the router’s GNSS (Global Navigation Satellite System) module N/A N/A
    MAXIMUM VEHICLE SPEED (KM/H) This setting helps to filter out erroneous location fixes by setting an expectation of the vehicle’s maximum achievable speed. 0—1000 250
    LOCATION CONSTELLATION Location constellation you want the router to use
    • GPS Only
    IGNITION PARK MODE
    You can configure how GNSS location fixes are reported when Ignition is off. The setting can remedy Location Fixes drifting when vehicles are parked.
    • Non-DR Location Fixes (default)—Router will continue to report location fixes received while parked.
    • DR and Non-DR Location Fixes—Router will continue to report location fixes received while parked. Note: XR60 does not support DR (Dead Reckoning)
    • No Location Fix
    On
    GNSS ANTENNA DETECTION Enable/Disable the reporting of GNSS Antenna State under Status > Status > Location. When disabled, GNSS Antenna State is reported as Not available. Off, On Off
    Parked Vehicle Location
    The Parked Vehicle Location settings determine how GNSS location fixes are reported when vehicle ignition is off. The setting can remedy Location Fixes drifting when vehicles are parked. To modify these settings, you must set Telemetry > Vehicle > VEHICLE IGNITION WIRING to “Connected to AirLink gateway GPIO input line” or “Connected to AirLink gateway Ignition Sense input line”.
    REPORT
    Selects what location fix the router reports when the vehicle ignition is turned off.
    • Current Location Fix—The router’s GNSS module continues reading and reporting location fixes when the ignition is off. The EXCLUDE DEAD-RECKONING FIXES setting (below) determines whether pure dead-reckoning fixes are reported in this mode.
    • No Location Fix
    Configuring Location Reports
    Under Location > Reporting:
    Local Reporting
    To configure Local Reporting:
    1. Click CREATE below the LOCAL REPORTING table.
    2. In the Create Local Reporting window, configure the following settings:
    DESTINATION LAN SEGMENT
    n/a n/a
    REPORT TYPE
    • NMEA
    • NMEA
    • TAIP PV report
    • TAIP CP report
    • TAIP LN report
    • TAIP TM report
    NMEA
    SENTENCES
    Remote Reporting
    1. Click CREATE below the REMOTE REPORTING SERVER table.
    2. In the Create Remote Reporting Server window, configure the following settings:
    DESTINATION HOSTNAME OR IP
    NOTE: If you want to use it as a LAN device, it must have a private IP address. If you want to use a public IP address, use a Local IP report.
    n/a n/a
    REPORT TYPE
    • NMEA
    • NMEA
    • TAIP PV report
    • TAIP CP report
    • TAIP LN report
    • TAIP TM report
    NMEA
    SENTENCES
    2. Go to Hardware Interfaces.
      • PAD MODE: UDP
      • DESTINATION ADDRESS: Same Destination IP Address used in Step 1. For example 192.168.1.1.
    5. Click SAVE.
      • REPORT TITLE: enter a report name.
      • REPORT CONTENT: select GPIO ARA from the list.
        GPIO ARA consists of the following data points:
      • atp.gpi: GPIO Input Cumulative, which is a binary report of the Primary GPIO Input (on power connector): atp.pgpio
    4. Click CREATE.
    5. To generate a report on state change of the GPIO input, go to UNCONDITIONAL TRIGGERS and click CREATE UNCONDITIONAL TRIGGERS.
      • NAME: Enter a trigger name
      • ENABLE: Enable the trigger
    7. Click CREATE.
    8. Under Telemetry > MQTT, configure the connection to your MQTT server. See Configuring Telemetry for more information about MQTT settings.
