    Getting Started & Features
    AirLink OS is a powerful software application that enables you to configure, monitor, and analyze Sierra Wireless gateways and associated applications/accessories. You can access AirLink OS directly over a physical or LAN connection to the device, or on AirVantage.
    Shortcuts for common tasks
    Feature Icon Description
    Search
    Click to search for a feature or setting you want to view or configure. Enter a setting name like “LDAP” to find all settings that use that name, or enter a setting value like “IPv6” to find every place that value is entered. Press [ESC] to exit the Search results and return to the main screen.
    Notifications
    Click the icon to view notifications. Notifications might include…
    Template
    Click to create, modify or apply a device template. For more information, see the section on device templates.
    Logout
    Click to log out of AirLink OS. By default, AirLink OS logs you out after 5 minutes of inactivity. You can configure the Session Idle Timeout setting on the Services > Web > Session menu.
    More
    Clicking the More icon allows you to enable Development Mode.
    Basic navigation
    Other tips
    You can click the arrow (>) in the status bar to view every setting that you’ve modified so far. If you need to revert any of your changes-in-progress, click UNDO next to any of the individual lines or to revert everything.
    When you’re all done, click SAVE to push your changes to the gateway.
