Templates are the easiest, fastest method for configuring multiple AirLink routers. AirLink OS gives you several options for creating, modifying and applying templates.
To start working with templates from AirLink OS, click the Templates icon
and select an option:
The AirLink OS screen banner changes color and states TEMPLATE mode is ON. In Template mode, check boxes appear next to text boxes, table rows, and tables.
To cancel template mode, click the Cancel icon
or CANCEL on the Template status bar (see below).
You may want to use this option to create a template with only a few important settings, and then apply that template to multiple routers later.
To create a template:
Click Create template from scratch.
You can now begin adding settings to your template.
To add a setting, select the checkbox for a setting. The setting and its current value will be added to the template.
to delete/reset a table row (or an entire table) in the template.
To save the template, click EXPORT TO JSON, and then save the file.
- For security reasons, passwords are not automatically saved to a new template. If you select any password settings, please re-enter the password before saving the template.
Instead of selecting a few settings to apply to multiple routers, this option creates a template using all settings that were modified by a user (different from their factory default). You may want to use this method when you have a configured device and want to deploy additional devices “out of the box” based on that one configured device.
Click Create template from current configuration.
When you’re ready to save the template, click EXPORT TO JSON, and then save the file.
You can open an existing template, update and add settings to it, and then save the template for future use.
To modify a template:
Click Modify a template from local file.
Browse to your file and then click Open. The template loads into your browser, and Template mode is ON.
To apply a template:
Click Apply a template.
Browse to your template file, and then click Open.
A confirmation message appears.
On the status bar, click > to view which settings the template will update.
