| HTTP ACCESS | Configure HTTP AirLink OS WAN access | Enable, Disable, Redirect to HTTPS | Redirect to HTTPS (RECOMMENDED) |
| HTTP PORT | Configure HTTP port for Airlink OS WAN access | 1 to 65535 | 80 |
| HTTPS ACCESS | Configure HTTPS Airlink OS WAN access | Enable/Disable | Enable |
| HTTPS PORT | Configure HTTPS port for Airlink OS WAN access | 1 to 65535 | 443 |
| HTTPS CERTIFICATE |
If using HTTPS, click |
N/A | N/A |
| HSTS | HTTP Strict Transport Security | Off/On | On |
| SESSION IDLE TIMEOUT | The amount of idle time required before the user is automatically logged out and redirected to the login screen. | 1 to 1440 mins | 5 mins |
| MAXIMUM LOGIN ATTEMPTS | The number of failed login attempts allowed before the user account is temporarily locked for the length of time specified in the UNLOCK TIME field. Disabling this feature is not recommended. | 0(disabled) to 5 | 3 |
| UNLOCK TIME | The length of time that the user account is locked after the maximum number of failed login attempts. Configured in MAXIMUM LOGIN ATTEMPTS field. | 1 to 3600 seconds (1 hour) | 120 seconds (2 minutes) |
• LDAP, RADIUS, and TACACS+ are supported for AirLink OS logins, but are not supported by other AirLink gateway services such as Telnet, SSH, etc.
This section enables the configuration of LDAP version 3 servers for use by the AirLink gateway to perform user authentication.
| FILE NAME | Required file name | N/A | N/A |
| SERVER | Required LDAP server IP address or resolvable domain name | N/A | N/A |
| PORT | Port number | 1 to 65535 | 389 |
| TIMEOUT |
| ENCRYPTION | Encryption type. |
start_tls |
| BASE DN | The Base DN is the path in the LDAP tree to the list of users (e.g. dc=sierrawireless,dc=com). This is where the LDAP protocol searches for a matching user to authenticate. | N/A | N/A |
| BIND | Choose how the LDAP search is done |
anonymous |
| BIND DN | This field only appears if you selected Explicit in the BIND field. The full path of the user authorized to perform requests in the LDAP | N/A | N/A |
| BIND PASSWORD | This field only appears if you selected Explicit in the BIND field. Password associated with the Bind DN | N/A | N/A |
| CONFIGURATION FILE NAME | Required configuration file name | N/A | N/A |
| SERVER | Required RADIUS server IP address or resolvable domain name | N/A | N/A |
| PORT | Port number | 1 to 65535 | 1812 |
| TIMEOUT |
| SECRET | Shared secret for configured server | N/A | N/A |
| SERVER | Required TACACS+ server IP address or resolvable domain name | N/A | N/A |
| PORT | Port number | 1 to 65535 | 49 |
| TIMEOUT |
| AUTHENTICATION PROTOCOL | Shared secret for configured server |
PAP |
| SECRET | The type of bind used for authentication | N/A | N/A |
| LEGAL TEXT INSIDE LOGIN ZONE | This will display the text inside the login zone under the SIGN IN button |
| LEGAL TEXT OUTSIDE LOGIN ZONE | This will display the text outside the login zone |
Example:
