Container applications allow you to deploy Open Container Initiative (OCI)-compatible containers to the router to run applications or computational workloads locally. This way, you can extend the functionality of the router or run applications in the router without impacting router behavior.
Common container application use cases include data acquisition, IIoT, and data store and forward, among many others.
OCI container support enables the use of many Docker-based images and registries.
The Container Application support is currently in the Early Adopter phase and is targeted to technical customers who wish to deploy container applications into production environments. Early adopter customers should understand and be comfortable with the current solution limitations, listed below, if they are going to be used in production.
Semtech will provide support for the container application framework but is not responsible for the support or troubleshooting of the users’ container application(s). It is the responsibility of the end customer to verify the container application functions as expected on Semtech routers.
While Semtech will endeavor to maintain compatibility and resource availability between AirLink OS versions, container applications should be tested and verified to ensure they function as expected on new versions prior to upgrade or deployment.
Using container applications in production environments requires an Edge Compute add-on license per router. Please contact your Semtech partner for more information.
An Edge Compute add-on license is not required in the following situations:
The following memory and flash resources are available to container applications on the AirLink routers listed below. The container image must be built for the associated CPU architecture.
Resource availability is subject to change between AirLink OS releases.
| AIRLINK ROUTER | MEMORY | FLASH | CPU |
| XR60 | 1.2 GB | 750 MB | Quad-core ARMv8 64-bit |
| XR80 | 200 MB | 750 MB | Quad-core ARMv8 64-bit |
| XR90 | 200 MB | 750 MB | Quad-core ARMv8 64-bit |
| RX55 Wi-Fi Plus* | 200 MB | 2.8 GB | Dual-core ARMv7 32-bit |
*The non-WiFi Plus RX55 models have limited resourcing and are not recommended for container applications. Container application support for these devices will be removed in a future release.
You can configure container applications in the following sections under Container Applications (Early Adopter).
Under General Status, you can Enable container applications on the router and view container status.
To enable the router to pull the application image and allow applications to run, you must enable the container applications feature on the router.
To enable container applications:
Click ENABLE. The switch should display Enabled.
Click SAVE.
Under Containers Status you can create and run the container application.
In the CONTAINER LIST table, you can view container parameters, retrieve container logs and manually stop and start the container.
To create the container application:
Go to Container Applications > Containers Status.
Click CREATE CONTAINER APPLICATION. The Create Container Application menu appears.
- There is a limit of five containers that can be configured through the AOS UI.
- Each container has a fixed RAM limit of 100MB.
- If the amount of RAM used by the configured container goes above 100MB, processes will be killed in order of decreasing RAM utilization until the usage is below 100MB. If the terminated process was a root process, the container would stop with an exit code of 137. For such container failures, respective configured restart policy would be applied.
- You can define up to five containers, which would result in a total RAM usage of 500MB — exceeding the device’s memory limit. This is not recommended, as it may lead to unexpected behavior or system instability.
Configure the settings as described below and then click CREATE.
| NAME | Name for the container application | blank | n/a |
| AUTOSTART | Enable automatically starting the container when the router reboots. | Enabled | Enabled, Disabled |
| RESTART POLICY |
Select the restart behavior when the container stops.
On-Failure Restart | On-Failure Restart, No Restart |
| RESTART MAX RETRIES |
Set the maximum number of automatic restart attempts. When this number is exceeded, the container will not restart automatically. The current number of restart attempts is reset after a router reboot. The restart delay is fixed at 1 minute. |
10 | 1–100 |
| IMAGE |
Select the container image from the locally available images. |
blank | Any locally available images, or click CREATE to enter an image reference and registry configuration |
| VOLUMES |
Select the volume from the locally available volumes. |
blank | Any available volumes, or click CREATE to create a container volume |
| LAN SEGMENT |
Select the LAN Segment that the container will run on. |
Default-LAN | Any available LAN Segments, or click CREATE to create a LAN Segment |
| COMMAND |
Leave blank to start the application using the ENTRYPOINT and/or CMD specified in the container image. Optionally, enter a command to start the application, overriding any commands in the container image. |
blank | n/a |
| IPV4 AUTO ASSIGNMENT |
Enable to perform a DHCP request once when the container starts. |
On | On, Off |
| IPV6 AUTO ASSIGNMENT |
Enable to perform a router solicitation once when the container starts. |
On | On, Off |
Under Images, you can install images on the router by pulling from a registry or local upload (using the UPLOAD NEW APPLICATION IMAGE button).
FREE SPACE ON CONTAINER FLASH PARTITION reports the remaining free space on the partition.
In the IMAGES table, you can view image parameters, see status information, and manage the image.
To pull an image from the registry:
Click PULL IMAGE FROM A REGISTRY. The Create Pull Image From A Registry menu appears.
Enter the IMAGE REFERENCE. The reference is the path to the image file in the registry.
Under SELECT REGISTRY CONFIGURATION, click x and select the Registry Configuration name.
Click CREATE.
Click SAVE.
The router begins pulling the application image (you can view progress in the Status column).
In certain scenarios (debugging, for example), you may need to upload the application image locally (that is, using a laptop connected directly to the router). The image must be in a .tar file.
To upload the image locally:
Go to Container Applications > Images.
Click UPLOAD NEW APPLICATION IMAGE.
Upload the image .tar file.
Verify that the image upload was successful, and the image is listed in the IMAGES table.
- Uploading the image can take several minutes, depending on image size.
- Images uploaded locally cannot be included in templates. If you need to deploy containers across a fleet of routers using templates, you must pull the image from a repository.
Under Registry Access, you can configure a link to the image registry from which the router can obtain container images.
The SECURE PULL setting enables or disables pulling an image from a registry with an HTTP URL, or to skip HTTPS certificate verification.
In the REGISTRY ACCESS CONFIGURATIONS TABLE, you can view information about your configured repositories.
To get the application image from a remote source, the router must access the registry where the image resides. The router is pre-configured to access the Amazon-ECR-Public registry and the DockerHub-Public registries, as shown in the REGISTRY ACCESS CONFIGURATIONS table.
When using a private APN network, ensure that the router can DNS resolve the FQDN where the application image is hosted and can communicate (outbound initiated) to the resolved URL using HTTPS (on port TCP/443).
To configure registry access:
If required, disable SECURE PULL to allow pulling an image from a registry with an HTTP URL, or to skip HTTPS certificate verification. Note: Do not disable SECURE PULL in a production deployment, as it can lead to using untrusted sources.
Click CREATE REGISTRY ACCESS CONFIGURATION. The Create Registry menu appears.
Enter the registry NAME. This name cannot be edited after the registry is created.
Enter the full URL to the registry.
Select the AUTHENTICATION MODE: None (default–the server enables public access) or Basic (the server uses access control based on HTTP basic authentication).
If you have selected Basic for the AUTHENTICATION MODE, enter the USERNAME and PASSWORD. If required, select the CERTIFICATE to validate HTTPS connection. You can select an existing certificate (see Security > Certificates) or create/upload a new Registry Server certificate.
Container volumes can be used to create persistent directories that can be used within a container or shared across containers. A volume can also be used to deliver configuration to the container outside of an image update.
There are two types of container volumes.
To create the container volume:
Go to Apps > Container Applications > Volumes.
Click CREATE CONTAINER VOLUME. The Create Container Volume menu appears.
Enter a NAME; config, for example.
Enter the MOUNT POINT for the volume. This will be used when mounting the volume into the directory. For example, using /data for the mount point will result in this volume being mounted to /data within the container.
For a configuration volume, upload the .tar file.
Click CREATE.
Verify that the volume appears in the VOLUMES table.
You can use the AirLink OS interface to verify that you have installed and started the container.
To verify the container is working:
To update a container image on the router to a newer version, you must:
The system will automatically stop the container and restart it to use the new image.
This update can be done in one operation using a template if the router obtains the new container image using a registry pull.
