    Table of Contents
    • ENABLE: Turns the cellular interface On or Off. When Off, the Adapter Status changes to Standby.
    • MEDIA STATUS: Status of the network connection. This reports whether the antenna is present and a cellular network signal is detected. In some cases, the router may get a cellular network signal even when the antenna is not connected.
      • Check Manual Radio Firmware: Validating that the required radio module firmware (if Radio Firmware Switching is set to “Manual”) is present and active
      • MultiApn: Checking whether the SIM configuration requires the Cellular interface to operate in Multi APN mode
      • Standby: The cellular interface is Off (using the Enabled button), or it is enabled and no cellular network signal has been detected yet
      • Monitoring Virtual: The adapter is in Multi APN mode, with configured virtual APNs
    • RADIO FIRMWARE SWITCHING: By default, the router automatically selects the radio module firmware. To force the router to use a radio module firmware for a different carrier, change RADIO FIRMWARE SWITCHING to Manual, and then select a radio firmware from the list.
      • Automatic: The router automatically selects and uses the appropriate radio module firmware for the active SIM card. (default)
      • Manual:The router does not automatically select the appropriate radio module firmware when it is powered on or rebooted. You must select the radio firmware.
    • SIM CONFIGURATION NAME: By default, the XP1 and XP2 SIMs and associated configuration are included in the SIM Database. You can enter a name for the SIM Configuration in this field. The name appears in the SIM Database.
    • PREFERRED TECHNOLOGY: Restricts the router to using a specific cellular technology: Auto (default), 3G Only, 4G Only, 5G-SA Only (5G Standalone).
    LPWA - Out-of-Band Management
    • ENABLE: Turn the LPWA interface on or off
      • Initializing
      • Initializing SIM
      • Configuring
      • Connecting
      • Connected
      • Standby
      • Wait For Update
    • MTU: The MTU Transmission Unit in use
    Multi-APN Configuration
    In the example below, the default cellular interface XP1 has sub-interfaces XP1 Cellular-1 and XP1 Cellular-2. These additional APNs are the potentially active interfaces.
