For automatic Network Operator Switching to work, the router must have the radio module firmware corresponding to the network operator loaded and displayed in the RADIO MODULE FIRMWARE table. It can also work if the generic RMFW loaded and displayed is compatible with the network operator. The following steps describe how to ensure that the required radio module firmware is loaded onto the router.
In the above example,
The update will retrieve the RMFW and add it to the router. After reboot, the router executes several checks and the RMFW image switch occurs based on the SIM that was inserted, as indicated by the green LED chase pattern. The update should take about 2–5 minutes, depending on the RMFW version it is updating to.
When NETWORK OPERATOR SWITCHING setting is set to Manual, you can manually switch the radio module firmware to a specific network operator using this process. You can check the NETWORK OPERATOR SWITCHING setting in the Hardware Interfaces > Cellular Interfaces > Cellular section.
Power the router on.
Go to Hardware Interfaces > Cellular Interfaces.
Under Cellular > NETWORK OPERATOR SWITCHING, click Automatic to switch it to Manual.
Under SELECT NETWORK OPERATOR, select your desired carrier.
Click SAVE.
The Cellular ADAPTER STATUS indicates Initializing and then Updating Firmware within a few seconds, as indicated by the green LED chase pattern. The update should take about 2–5 minutes depending on the RMFW version it is updating to.
| CARRIER | RMFW VERSION |
| AT&T/FirstNet | 03.14.10.04 |
| Bell | 03.14.10.01 |
| Generic | 03.14.10.04 |
| Rogers | 03.14.10.01 |
| Telstra | 03.10.07.00 |
| Telus | 03.14.10.00 |
| T-Mobile | 03.14.10.01 |
| Verizon | 03.14.10.00 |
| AT&T | 02.15.01.00 |
| Generic | 02.15.01.00 |
| T-Mobile | 02.15.01.00 |
| Verizon | 02.17.08.00 |
| Generic | 4.7.1.4 |
