Solid Green
Solid Yellow
Solid Red
Fast Flashing Red
Slow Flashing Red
Off
Slow Flashing Green
Slow Flashing Purple
Off
| RSSI | RSSI | RSRP | SNR | |
Slow Flashing Green
Slow Flashing Red
Off
Slow Flashing Green
Slow Flashing Red
Off
Solid Green
Fast Flashing Green
Solid Yellow
Fast Flashing Yellow
Solid Red
Fast Flashing Red
Slow Flashing Red
Off
A yellow LED chase pattern indicates a software update in progress (a XR router firmware update, radio module firmware update, etc.)
