WP76xx Firmware Release 12.0.1 Components
  • May 23, 2022
  • Version: 2.0
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 12.0.1 components and how to download it on your product.
WP76xx Firmware Release 12.0.1 combined image
SWI9X07Y_02.18.05.00 / 002.041_005
Modem Firmware (Generic — GCF)  SWI9X07Y_02.25.02.01 / 002.056_002  Download   Custom Modem Firmware can NOT be created by customers
Modem Firmware (AT&T)
SWI9X07Y_02.18.05.00 / 002.040_003
Modem Firmware (Verizon)
SWI9X07Y_02.18.05.00 / 002.041_003
Modem Firmware (Sierra Wireless (PTCRB))  SWI9X07Y_02.18.05.00 / 001.002_004  Download   Custom Modem Firmware can NOT be created by customers
Modem Firmware (Sierra Wireless (GCF))
SWI9X07Y_02.25.02.01 / 001.014_002
002.011
SWI9X07Y_02.25.04.01
18.10.3
18.10.3 Source
SWI9X07Y_02.25.04.01 Source
(Based on Kernel 3.18.122 and Yocto 2.2.2)
Note: The Linux Distro Source, ONLY purposed for rebuilding the Linux Distribution, has been updated with "SWI9x07Y_02.37.10.01 - for example"  and correctly configured in order to accommodate changes made through new memory driver updates. No impact on all the shipping SKU's directly from factory.
WP76xx Firmware Release 12.0.1 Components | Source
