WP76xx Firmware Release 13.1.1/13.2.1/13.3.1 Components
  • May 23, 2022
  • Version: 2.0
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 13.1.1, 13.2.1 and 13.3.1 components and how to download it on your product.
Release 13.1/13.2/13.3 Components
WP76xx Firmware Release 13.1/13.2/13.3 combined image
(R13.1.1) SWI9X07Y_02.28.03.03 / 002.068_003
(R13.2.1) SWI9X07Y_02.28.03.03 / 002.068_002 Download
 (R13.3.1) SWI9X07Y_02.28.03.05 / 002.073_001 Download
(R13.1.1) SWI9X07Y_02.28.03.01 / 002.064_003
 (R13.2.1) SWI9X07Y_02.28.03.01 / 002.064_002 Download
Modem Firmware (AT&T)
(R13.2.1) SWI9X07Y_02.28.03.01 / 002.071_006
Modem Firmware (DOCOMO)
(R13.3.1) SWI9X07Y_02.28.03.05 / 001.024_001 Download
Modem Firmware (KDDI)
(R13.3.1) SWI9X07Y_02.28.03.05 / 001.026_002 Download
Modem Firmware (Softbank)
(R13.3.1) SWI9X07Y_02.28.03.05 / 001.028_001 Download
Modem Firmware (Telstra)
(R13.3.1) SWI9X07Y_02.28.03.05 / 001.058_001 Download
Modem Firmware (Telus)
(R13.2.1) SWI9X07Y_02.28.03.01 / 001.000_002 Download
Modem Firmware (Verizon)
(R13.2.1) SWI9X07Y_02.28.03.04 / 002.075_002
Modem Firmware (Sierra Wireless— GCF)
(R13.1.1) SWI9X07Y_02.28.03.03 / 001.026_003
(R13.2.1) SWI9X07Y_02.28.03.03 / 001.026_002 Download
(R13.3.1) SWI9X07Y_02.28.03.05 / 001.032_001 Download
002.011
(R13.1.1) SWI9X07Y_02.28.06.02
(R13.2.1) SWI9X07Y_02.28.05.03
(R13.3.1) SWI9X07Y_02.28.04.02
19.02.0
 Legato Source Release #
19.02.0 Source
 R13.1.1 (Based on Kernel 3.18.131 and Yocto 2.5)
SWI9X07Y_02.28.06.02 Source
 R13.2.1 (Based on Kernel 3.18.131 and Yocto 2.5)
SWI9X07Y_02.28.05.03 Source
32-bit ToolChain
 R13.3.1 (Based on Kernel 3.18.131 and Yocto 2.5)
SWI9X07Y_02.28.04.02 Source
32-bit ToolChain
Note: The Linux Distro Source, ONLY purposed for rebuilding the Linux Distribution, has been updated with "SWI9x07Y_02.37.10.01 - for example"  and correctly configured in order to accommodate changes made through new memory driver updates. No impact on all the shipping SKU's directly from factory.
WP76xx Firmware Release 13.1.1/13.2.1/13.3.1 Components | Source
