WP76xx Firmware Release 13 Components
  • Jun 12, 2019
  • Version: 13
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 13 components and how to download it on your product.
WP76xx Firmware Release 13 combined image
SWI9X07Y_02.28.03.01 / 002.064_000
Modem Firmware (AT&T)
SWI9X07Y_02.28.03.01 / 002.071_000
002.011
19.02.0
19.02.0 Source
SWI9X07Y_02.28.03.01 Source
(Based on Kernel 3.18.122 and Yocto 2.5)
