WP76xx Firmware Release 16.3 Components
- Dec 14, 2022
- Version: 1.0
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 16.3 components and how to download it on your product.
WP76xx Firmware Release 16.3 combined image
| Modem Firmware (Generic — GCF and PTCRB) |
SWI9X07Y_02.37.06.05 / 002.121_002 |
| Modem Firmware (AT&T) |
SWI9X07Y_02.37.03.05 / 002.126_000 |
| Modem Firmware (T-Mobile) |
SWI9X07Y_02.35.02.00 / 001.017_001 |
| Modem Firmware (Verizon) |
SWI9X07Y_02.37.06.05 / 002.123_000 | Download |
| Modem Firmware (DOCOMO) |
SWI9X07Y_02.28.03.05 / 001.024_001 | Download |
| Modem Firmware (KDDI) |
SWI9X07Y_02.28.03.05 / 001.026_002 |
| Modem Firmware (LGU) | SWI9X07Y_02.32.03.01 / 001.026_001 | Download | Custom Modem Firmware can NOT be created by customers |
| Modem Firmware (SoftBank) | SWI9X07Y_02.28.03.05 / 001.028_001 | Download | Custom Modem Firmware can NOT be created by customers |
| Modem Firmware (Telstra) | SWI9X07Y_02.28.03.05 / 001.058_001 | Download | Custom Modem Firmware can NOT be created by customers |
| Modem Firmware (Sierra) | SWI9X07Y_02.37.06.05 / 001.072_000 |
002.015 |
SWI9X07Y_02.37.10.02 |
19.11.6 |
| Legato Source | Release # |
Linux Distro Source | Linux Distro Licences |
| 19.11.6 Source |
R16.3 | (Based on Kernel 3.18.140 and Yocto 2.5) SWI9X07Y_02.37.10.02 Source |
