WP76xx Firmware Release 17.1.1
- Nov 4, 2026
- Version: 1
This page describes the procedure to update WP76xx with Firmware Release 17.1.1
WP76xx Release 17.1.1 is a maintenance release that delivers critical security patches, bug fixes, and stability improvements to enhance system reliability.
WP76xx firmware is available:
- As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 17.1.1 Updates, below.
See WP76xx Firmware Release 17.1.1 Components to create custom firmware packages.
Important note for the 2-stage AV FOTA firmware upgrade:
- All legacy firmware releases can only be upgraded by AV FOTA to the latest version via Firmware 16.3. The AV FOTA process to intermediate Firmware Release 16.3 must firstly be completed before proceeding to the AV FOTA process of upgrading to Firmware Release 17 and later versions such as Firmware Release 17.1.1.
- No firmware downgrade back to prior firmware releases is allowed once the firmware is upgraded to Release 17.1.1.
1. If not already done, download the latest USB driver and launch the executable.
3. Connect the target's (e.g mangOH) USB cable to your host |
| MBPL (Linux) |
2. Follow instructions from the Software Integration and Development Guide for Linux USB Platforms included in the MBPL (Mobile Broadband Package for Linux). |
| Leaf Workspace Manager |
For details about this firmware release, refer to the WP76xx Release 17.1 Customer Release Notes.
| Carrier Approval |
| AT&T Data |
SWI9X07Y_02.37.12.02 / 001.005_000 | 002.015 |
SWI9X07Y_03.01.14.00 | 21.05.5 |
| AT&T VD | SWI9X07Y_02.37.12.02 / 001.007_000 | 002.015 | SWI9X07Y_03.01.14.00 | 21.05.5 |
| Generic Data | SWI9X07Y_02.37.12.02 / 001.007_000 | 002.015 | SWI9X07Y_03.01.14.00 | 21.05.5 |
| Generic VD | SWI9X07Y_02.37.12.02 / 001.009_000 | 002.015 | SWI9X07Y_03.01.14.00 | 21.05.5 |
| T-Mobile (TMO) Data | SWI9X07Y_02.37.12.02 / 001.006_000 | 002.015 | SWI9X07Y_03.01.14.00 | 21.05.5 |
| T-Mobile (TMO) VD | SWI9X07Y_02.37.12.02 / 001.006_000 | 002.015 | SWI9X07Y_03.01.14.00 | 21.05.5 |
| Verizon Data | SWI9X07Y_02.37.12.02 / 001.007_000 | 002.015 | SWI9X07Y_03.01.14.00 | 21.05.5 |
| Verizon VD | SWI9X07Y_02.37.12.02 / 001.013_000 | 002.015 | SWI9X07Y_03.01.14.00 | 21.05.5 |
| SIERRA | SWI9X07Y_02.37.12.02 / 001.087_000 | 002.015 | SWI9X07Y_03.01.14.00 | 21.05.5 |
