WP76xx Firmware Release 17.1.1 Components
- Nov 4, 2026
- Version: 1
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 17.1.1 components and how to download it on your product.
| Modem Firmware (AT&T Data) |
SWI9X07Y_02.37.12.02 / 001.005_000 |
| Modem Firmware (AT&T VD) |
SWI9X07Y_02.37.12.02 / 001.007_000 |
| Modem Firmware (Generic Data) |
| Modem Firmware (Generic VD) |
SWI9X07Y_02.37.12.02 / 001.009_000 | Download |
| Modem Firmware (Verizon Data) |
SWI9X07Y_02.37.12.02 / 001.007_000 | Download |
| Modem Firmware (Verizon VD) |
SWI9X07Y_02.37.12.02 / 001.013_000 |
| Modem Firmware (T-Mobile Data) | SWI9X07Y_02.37.12.02 / 001.006_000 | Download | Custom Modem Firmware can NOT be created by customers |
| Modem Firmware (T-Mobile VD) | SWI9X07Y_02.37.12.02 / 001.006_000 | Download | Custom Modem Firmware can NOT be created by customers |
| Modem Firmware (Sierra) | SWI9X07Y_02.37.12.02 / 001.087_000 | Download | Custom Modem Firmware can NOT be created by customers |
002.015 |
SWI9X07Y_03.01.14.00 |
21.05.5 |
| Legato Source | Release # |
Linux Distro Source | Linux Distro Licences |
| legato-21.05.5.tar.bz2 |
R17.1 | SWI9X07Y_03.01.14.00 Source | Open Source Licenses | 32-bit ToolChain 64-bit ToolChain |
