WP76xx Firmware Release 6.2.0.1 Components
- Dec 1, 2021
- Version: 6.2.0.1
WP76xx Firmware Release 6.2.0.1 combined image
| Modem Firmware (Verizon) |
SWI9X07Y_02.10.00.00 / 002.014_003 |
002.005 |
SWI9X07Y_02.11.02.00 |
17.09.0 |
| 17.09.0 Source |
SWI9X07Y_02.11.02.00 Source (Based on Kernel 3.18 and Yocto 1.7) |
Note 1: you may decide to generate a custom Device Image without the full list of components (e.g. without Modem Firmware or without the Linux Distribution). If you do so, when you will flash this image later, only the components included within the custom Device Image package will be updated, the others will remain untouched. By doing this, you shall insure that the untouched components are compliant with the ones you are updating through the custom Device Image.
