WP76xx Firmware Release 7.0.1 Components
- Feb 5, 2018
- Version: 7.0.1
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 7.0.1 components and how to download it on your product.
WP76xx Firmware Release 7.0.1 combined image
SWI9X07Y_02.13.02.00 / 002.018_001 |
SWI9X07Y_02.10.01.00 / 002.015_001 |
| Modem Firmware (AT&T) |
| Modem Firmware (Verizon) |
SWI9X07Y_02.10.00.00 / 002.014_002 |
002.006 |
SWI9X07Y_02.13.02.00 |
17.11.0 |
| 17.11.0 Source |
SWI9X07Y_02.13.02.00 Source (Based on Kernel 3.18 and Yocto 2.2) |
