WP77xx Firmware Release 11 Components
  • Oct 1, 2019
  • Version: 11
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 11 components and how to download it on your product.
WP77xx Firmware Release 11 combined image
SWI9X06Y_02.22.12.00 / 001.051_000
SWI9X06Y_02.16.06.00 / 001.028_004
Modem Firmware (AT&T)
SWI9X06Y_02.16.06.00 / 001.026_001
Modem Firmware (Sierra Wireless — GCF)
SWI9X06Y_02.22.12.00 / 001.021_000
Modem Firmware (T-Mobile US)
Modem Firmware (Verizon)
SWI9X06Y_02.22.12.00 / 001.042_000
002.011
18.09.2
18.09.2 Source
SWI9X06Y_02.22.12.00 Source
(Based on Kernel 3.18 and Yocto 2.2)
WP77xx Firmware Release 11 Components | Source
