WP77xx Firmware Release 7 Components
- Jan 13, 2018
- Version: 7
WP77xx Firmware Release 7 combined image
| Modem Firmware (Generic — GCF/PTCRB approval pending) |
002.006 |
SWI9X06Y_02.13.02.00 |
17.11.0 |
| 17.11.0 Source |
SWI9X06Y_02.13.02.00 Source (Based on Kernel 3.18 and Yocto 2.2) |
