WP77xx Firmware Release 9.1 Components
  • Aug 18, 2018
  • Version: 9.1
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 9.1 components and how to download it on your product.
WP77xx Firmware Release 9.1 combined image
Modem Firmware (Generic — GCF/PTCRB)
SWI9X06Y_02.16.06.00 / 001.028_001
Modem Firmware (AT&T
SWI9X06Y_02.16.06.00 / 001.026_000
Modem Firmware (T-Mobile US)
002.009
SWI9X06Y_02.18.05.00
18.06.1
18.06.1 Source
SWI9X06Y_02.18.05.00 Source
(Based on Kernel 3.18 and Yocto 2.2)
WP77xx Firmware Release 9.1 Components | Source
