WP77xx Firmware Release 9 Components
Jun 05, 2018 - Author: Sierra Wireless - Version 9 - 4517 Views
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 9 components and how to download it on your product.
WP77xx Firmware Release 9 combined image
Modem Firmware (Generic — Not certified; test purposes only)
SWI9X06Y_02.16.04.00 / 001.021_000
Modem Firmware (AT&T — Not certified; test purposes only)
SWI9X06Y_02.16.04.00 / 001.019_000
Modem Firmware (T-Mobile US)
002.009
SWI9X06Y_02.16.02.00
18.03.0
18.03.0 Source
SWI9X06Y_02.16.02.00 Source
(Based on Kernel 3.18 and Yocto 2.2)
    • MCU Firmware: mcuFW.cwe
©2026 All rights reserved
