WP8548 & WP75xx Firmware Release 15
- Jan 13, 2018
- Version: 15
This page describes the procedure to update WP8548 & WP75xx with the Firmware Release 15.
1. Download the USB driver and launch the executable 2. Download the Firmware .EXE file according to your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R15 (Generic — GCF) R15 (Generic — PTCRB) R15 (AT&T) R15 (Sprint) 3. Connect the target's (e.g mangOH) USB cable to your host 4. Launch the executable and follow instructions |
Follow the Firmware Update Instructions with Developer Studio to download and install the following package: Legato for WP85/WP75 R15 (16.10.4.wp85-wp75-docker-201712131537) for Windows or Legato for WP85/WP75 R15 (16.10.4.wp85-wp75-native-x86_64-201712131538) for Linux |
1. Download the Firmware .SPK file according to your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R15 (Generic — GCF) R15 (Generic — PTCRB) R15 (AT&T) R15 (Sprint) 2. Connect the target's (e.g mangOH) USB cable to your host 3. Open a terminal and execute the Legato command line:
1. On AirVantage, monitor the system to be updated. 2. Select More > Install Bundle. 3. Select the desired firmware bundle: WP7502 (Generic) Release 15 WP7504 (ATT) Release 15 WP7504 (PTCRB) Release 15 WP7504 (Generic) Release 15 WP7504 (Sprint) Release 15 WP8548 (ATT) Release 15 WP8548 (PTCRB) Release 15 WP8548 (Generic) Release 15 4. Start the install procedure. The operation will now be "In progress" state and visible in the System Operations widget. |
Consult the WP8548 & WP75xx Release 15 Customer Release Notes
| Carrier Approval |
| Generic — GCF |
SWI9X15Y_07.12.14.00 / 001.034_000 |
002.004 |
SWI9X15Y_07.12.14.00 |
16.10.4 |
| Generic — PTCRB |
SWI9X15Y_07.12.09.00 / 001.033_000 |
002.004 |
16.10.4 |
| AT&T |
SWI9X15Y_07.12.09.00 / 001.028_000 |
002.004 |
16.10.4 |
| Sprint |
SWI9X15Y_07.12.09.00 / 001.020_000 |
002.004 |
16.10.4 |
If you build custom Linux Distribution or Base Legato System images for your product, see WP8548 & WP75xx Firmware Release 15 Components to create custom firmware packages.
