WP8548 & WP75xx Firmware Release 16
  • Sep 28, 2018
  • Version: 16
This page describes the procedure to update WP8548 & WP75xx with the Firmware Release 16.
      R16 (Generic — GCF)
      Legato for WP85/WP75 R16 (18.6.1.wp85-wp75-docker-201810021634) for Windows
      or
      Legato for WP85/WP75 R16 (18.6.1.wp85-wp75-native-x86_64-201810021635) for Linux
      R16 (Generic — GCF)
Consult the WP8548 & WP75xx Release 16 Customer Release Notes
Generic — GCF
SWI9X15Y_07.13.07.00 / 001.040_000
002.004
SWI9X15Y_07.13.05.00
18.06.1
If you build custom Linux Distribution or Base Legato System images for your product, see WP8548 & WP75xx Firmware Release 16 Components to create custom firmware packages.
