Solid Green
Solid Red
Fast Flashing Red
Slow Flashing Red
Off
Slow Flashing Green
Off
| RSSI | RSSI | RSRP | SNR | |
Slow Flashing Green
Slow Flashing Red
Off
Solid Green
Fast Flashing Green
Solid Yellow
Fast Flashing Yellow
Solid Red
Fast Flashing Red
Slow Flashing Red
Off
A yellow LED chase pattern indicates an AirLink OS software update in progress.
