This page shows you how to configure Wi-Fi for your AirLink RX55 router in Access Point mode and Client mode.
Each interface is configurable as Access Point (2.4GHZ or 5GHz) or Client (2.4GHz, 5GHz, or 2.4GHz + 5GHz).
The REGION field is the regulatory domain that the router Wi-Fi is using. It is determined by using either the Global Navigation Satellite System (GNSS) sensors in the router, or by the Mobile Country Code (MCC) or Mobile Network Code (MNC) received from the carrier and received directly by the receiver on the device. The router automatically loads the operating frequencies for that regulatory region on each Wi-Fi radio interface in the software and enables 802.11d for broadcasting the newly obtained country information. If the router is not able to determine the region, it uses a default region setting. For more information on supported channels, please refer to the Wi-Fi specifications in the AirLink RX55 Hardware User Guide .
For more information on supported channels, refer to the Wi-Fi specifications in the AirLink RX55 Hardware User Guide .
If the AirLink router cannot determine the region, the default region setting for that router variant determines whether the PLACEMENT switch appears.
For example, if an AirLink router EMEA variant cannot determine the region, the REGION appears as “Unknown (restricted)” and the PLACEMENT switch appears, with Indoor as the default.
NOTES:
- The region and, if applicable, PLACEMENT option applies to both AP and Client mode. In Client mode, the router will only be able to connect using the applicable channels.
- Available channels may differ, depending on the region’s regulatory requirements.
- Enabling DFS Channels will make DFS-specific channels available to both AP and Client mode regardless of the region and, if applicable, PLACEMENT option.
For details on how your router is determining its region, go to Status/Monitoring > Services > Geolocation.
at the end of a row for Wi-Fi A or Wi-Fi B in the WI-FI INTERFACES table (as shown above).
Best Practice recommendation: If 2.4GHz and 5GHz APs are configured on different LAN segments, use different SSIDs and security passphrases to make sure DHCP renews IP addresses when switching between the APs.
For all security modes except OPEN and WPA2-Enterprise, enter a SECURITY PASSPHRASE of at least 8 characters.
Enable LEGACY MODE to restore security option WPA (version 1) and support TKIP encryption for WPA/WPA2 modes. By default, this is disabled and only AES encryption is supported.
For WPA2-Enterprise security modes only, select the 802.11W option.
Enable AUTO-CHANNEL to have the router choose the channel on which to operate.
Enable DFS CHANNELS to open up more Wi-Fi channels for the router to use, while preventing the router interfering with channels used by radar equipment (near airports, for example). With DFS CHANNELS enabled, the router will switch channels if it detects radar equipment using the same channel. Unless you know that your other operating equipment is DFS capable, Sierra Wireless recommends leaving DFS CHANNELS disabled.
Set the BEACON INTERVAL to configure how often the router sends periodic messages (beacons) to advertise its availability. 100 milliseconds is the default setting.
Set the MAX NUMBER OF CLIENTS — Enter the maximum number of clients that can connect simultaneously to this access point interface. As a guideline, set a limit that is slightly higher than the number of clients you expect to connect. The default is 10, with a range of 1 to 10.
Set MSS CLAMPING — MSS (Maximum TCP Segment Size) Clamping controls the maximum packet size used for TCP connections between a local (LAN-side) host and a remote host over the Wi-Fi WAN interface. MSS Clamping helps avoid possible issues with sending and receiving large TCP packets over the WAN interface when other standard MTU mechanisms do not appear to be working with your installation. The options are:
MSS — When MSS CLAMPING is set to Manual, set the Maximum TCP Segment Size.
Select the CPU BINDING — This determines which interface the router’s operating system processes first when network packets arrive at Wi-Fi at the same time as other non-Wi-Fi interfaces. By default, no interface is favored; that is, processed first. Semtech recommends leaving CPU BINDING at default unless you are concerned about maximizing Ethernet or Cellular throughput when combined with Wi-Fi traffic. The options are:
To configure this feature:
To use a scanned SSID:
To create an SSID manually:
| SETTING | DESCRIPTION |
| TYPE | Root Certificate |
| NAME | Required name identifying the certificate |
| ROOT CERTIFICATE | Click to upload the root certificate file |
| TYPE | Certificate |
| PRIVATE KEY | Click to upload the private key |
Leave the MODE as Client.
Additionally, you can go to Status/Monitoring > System > Wi-Fi to view detailed Wi-Fi Client status, including bit rate and the active channel.
