    Radio Module Firmware Image Management
    Automatic radio module firmware image switching (based on Carrier SIM)
    1. Ensure the router is powered off.
    2. Insert the carrier SIM that you want to image switch to into the desired SIM Card (slot).
      • On the AirLink RX55, SIM Card (slot) 1 maps to the upper slot, and slot 2 maps to the lower slot.
    3. Power the router on.
    4. Log in to AirLink OS.
    5. Go to System > Admin > Radio Module Image Management.
    6. Check if the required RMFW is showing in the Radio Module Firmware list.
      • If the firmware is showing and the FIRMWARE VERSION is filled in, then it will automatically switch to the correct RMFW when SIM switching.
      • If the firmware is showing, but the FIRMWARE VERSION is blank, then continue with step 7.
      • If the required firmware is not shown, then you must load it manually on the router. See Manually loading RMFW on to Router
    7. Update AirLink OS or re-execute the Airlink OS update even if it is already updated, as described in Updating Airlink OS Software. The software update will take 1–2 minutes, as indicated by the yellow LED chase pattern. During the update, any specified RMFW images not on the router are loaded onto the router, but are not applied to the radio module yet. The router reboots when the software update is complete. After reboot, the router executes several checks and the RMFW image switch occurs based on the SIM that was inserted in Step 2 above, as indicated by the green LED chase pattern. The update should take about 2–5 minutes, depending on the RMFW version it is updating to.
    In the above example,
    • If a SIM with PLMN 20801 or 20820 is detected, the system will use BELL RMFW.
    • If a SIM with an ICCID starting with “89330121313814” is detected, TELSTRA RMFW will be used.
    Manually loading radio module firmware image on to the router
    1. Click CREATE.
    2. Click on the entry line to select the desired module/carrier combination from the list.
      If you don’t find your desired radio module/carrier combination in the list:
        a. Click on the entry line and click CREATE.
        b. Enter the new firmware name (Model ID / Firmware Name)
        c. Click CREATE to create an instance with this value.
    3. Click CREATE to add a radio module firmware entry in the table.
    4. Click SAVE and a new row for the selected carrier appears. The FIRMWARE CONFIGURATION and FIRMWARE VERSION fields are blank.
    5. Update AirLink OS or re-execute the Airlink OS update even if it is already updated, as described in Updating Airlink OS Software. The software update will take 1–2 minutes, as indicated by the yellow LED chase pattern.
    The update will retrieve the RMFW and add it to the router. After reboot, the router executes several checks and the RMFW image switch occurs based on the SIM that was inserted, as indicated by the green LED chase pattern. The update should take about 2–5 minutes, depending on the RMFW version it is updating to.
    Optional: Manual radio module firmware image switching
    When NETWORK OPERATOR SWITCHING setting is set to Manual, you can manually switch the radio module firmware to a specific network operator using this process. You can check the NETWORK OPERATOR SWITCHING setting in the Hardware Interfaces > Cellular Interfaces > Cellular section.
      • On the RX55, SIM Card (slot) 1 maps to the upper slot, and slot 2 maps to the lower slot.
    4. Go to Hardware Interfaces > Cellular Interfaces.
    5. Under Cellular > NETWORK OPERATOR SWITCHING, click Automatic to switch it to Manual.
    6. Under SELECT NETWORK OPERATOR, select your desired carrier.
    7. Click SAVE.
    The Cellular ADAPTER STATUS indicates Initializing and then Updating Firmware within a few seconds, as indicated by the green LED chase pattern. The update should take about 2–5 minutes depending on the RMFW version it is updating to.
    Radio Module Firmware Versions
    EM7411
    CARRIER RMFW VERSION
    AT&T/FirstNet 01.14.22.00
    Bell 01.14.13.00
    Rogers 01.14.03.00
    Sierra 01.14.03.00
    Telus 01.14.03.00
    T-Mobile 01.14.03.00
    Verizon 01.14.24.00
    EM7421
    Generic 01.14.22.00
    Sierra 01.14.03.00
