This page shows you how to enable the router for Advanced Mobility Reporting (AMR). AMR is an ALMS offering that provides data analysis and historical reporting for your AirLink routers. AMR enhances your lightweight AVL and fleet management capabilities with its extensive telemetry data collection and reporting features. For better insight into your device status and vehicle behavior, AMR is an ideal low-cost, cloud-based solution. The Reporting section of ALMS is currently available only to AMR users.
The AirLink RX55 router supports the following AMR reports:
The AirLink RX55 (Wi-Fi and Wi-Fi Plus) router also supports the following AMR reports:
For optimum reporting performance, connect the router’s ignition line (white wire on the power connector) to the vehicle ignition, and connect the router to the vehicle bus as described in the RX55 Hardware User Guide. Many reports will not function correctly if the router is not wired correctly.
Under Services > Telemetry > Vehicle set VEHICLE IGNITION WIRING to Connected to AirLink gateway Ignition Sense input line.
Under MCU > Power Management, configure the ignition SHUTDOWN DELAY to be at least 30 seconds.
