The complete telemetry data set can be sent to AirVantage allowing for the viewing of all Advanced Mobility Reports(AMR).
| ENABLE | When enabled, the full telemetry data set is sent to AirVantage so that all Advanced Mobility Reports(AMR) can be viewed. Only displays when Telemetry is enabled. | On/Off | On |
| REPORT MODE |
Report that will be generated when the device powers off. Note: Only one report can be selected and in situations where there is an abrupt power disconnect a report may not be generated. |
| AT EVERY SAMPLE OF… |
Example 2: WAN Ready
Example 3: Ignition Status
Example 4: Primary WAN
Options are:
Options are:
| <RELATIONAL OPERATOR> |
Options are:
Example: LEVEL Trigger
Options are:
Options are:
Example : EDGE Trigger
If you define an EDGE trigger to generate a report when vehicle speed >= 55 KPH, then samples C and L would each generate a report. These samples represent the moments when the configured EDGE threshold for vehicle speed was true. (i.e. Sample B is < 55 KPH and Sample C is >= 55 KPH; Sample K is < 55 KPH and Sample L is >= 55 KPH).
N/A | N/A |
None |
| TOPIC |
6Q1099009902AC24/test {
“atp.ser” :
“t”: 1693258321.3640001,
“v” : “6Q1099009902AC24”
“ts” : 1693268920.464
0 |
ATP FORMAT |
Individual Timestamp |
| CONNECTION SECURITY |
None |
| ROOT CERTIFICATE |
N/A |
