    RX Series routers are equipped with location tracking, enabling you to track the movements of a vehicle or other devices that move. This section describes how the router relays location information as well as other data for use with tracking applications.
    • Computer-Aided Dispatch/Automatic Vehicle Location (CAD/AVL): The router provides real-time location data to the server that tracks the location and other variables of the vehicle or asset.
    Hardware Requirements
    Ensure that a GNSS antenna is connected to the router. See the RX55 Hardware Guide for installation and antenna connection instructions. For compatible antennas sold by Semtech, see our website.
    Enabling Location
    • Starting
    • Device Unavailable
    • Waiting For New Fix
    • Location Fix Acquired
    On
    MAXIMUM VEHICLE SPEED (KM/H) This setting helps to filter out erroneous location fixes by setting an expectation of the vehicle’s maximum achievable speed. 0—1000 250 KM/H
    IGNITION PARK MODE
    You can configure how GNSS location fixes are reported when Ignition is off. The setting can remedy Location Fixes drifting when vehicles are parked.
    • Non-DR Location Fixes (default)—Router will continue to report location fixes received while parked.
    • DR and Non-DR Location Fixes—Router will continue to report location fixes received while parked. Note: RX55 does not support DR (Dead Reckoning)
    • No Location Fix
    Parked Vehicle Location
    The Parked Vehicle Location settings determine how GNSS location fixes are reported when vehicle ignition is off. The setting can remedy Location Fixes drifting when vehicles are parked. To modify these settings, you must set Telemetry > Vehicle > VEHICLE IGNITION WIRING to “Connected to AirLink gateway GPIO input line” or “Connected to AirLink gateway Ignition Sense input line”.
    REPORT
    Selects what location fix the router reports when the vehicle ignition is turned off.
    • Current Location Fix—The router’s GNSS module continues reading and reporting location fixes when the ignition is off. The EXCLUDE DEAD-RECKONING FIXES setting (below) determines whether pure dead-reckoning fixes are reported in this mode.
    • No Location Fix
    Configuring Location Reports
    Under Location > Reporting:
    • If required, turn off TAIP REPORT CHECKSUM. By default, TAIP reports include checksums. You may need to disable this setting when your CAD integration requires TAIP messages and reports without checksums.
    • If required, turn on FORCE “GP” TALKER ID. Enable this setting for CAD systems that support only the “GP” talker ID for key NMEA sentences (GGA, RMC, VTG). When OFF, NMEA sentences use the talker ID as provided by the GNSS module.
    Local Reporting
    To configure Local Reporting:
    1. Click CREATE below the LOCAL REPORTING table.
    2. In the Create Local Reporting window, configure the following settings:
    DESTINATION LAN SEGMENT
    n/a n/a
    REPORT TYPE
    • NMEA
    • NMEA
    • TAIP PV report
    • TAIP CP report
    • TAIP LN report
    • TAIP TM report
    NMEA
    SENTENCES
    Remote Reporting
    1. Click CREATE below the REMOTE REPORTING SERVER table.
    2. In the Create Remote Reporting Server window, configure the following settings:
    DESTINATION HOSTNAME OR IP
    n/a n/a
    REPORT TYPE
    • NMEA
    • NMEA
    • TAIP PV report
    • TAIP CP report
    • TAIP LN report
    • TAIP TM report
    NMEA
    SENTENCES
    2. Go to Hardware Interfaces.
      • PAD MODE: UDP
      • DESTINATION ADDRESS: Same Destination IP Address used in Step 1. For example 192.168.1.1.
    5. Click SAVE.
      • NAME: enter a report name.
      • REPORT TITLE: enter a report TITLE.
      • REPORT CONTENT: select GPIO ARA from the list. GPIO ARA consists of the following data points:
      • atp.gpi: GPIO Input Cumulative, which is a binary report of all five GPIO data points:
        • Primary GPIO Input (on power connector) 0th bit: atp.pgpio
        • GPIO Input 2 bit position 1: atp.gpio2
        • GPIO Input 3 bit position 2: atp.gpio3
        • GPIO Input 4 bit position 3: atp.gpio4
        • GPIO Input 5 bit position 4: atp.gpio5
          • Primary GPIO Input: true
          • GPIO Input 2: true
          • GPIO Input 3: false
          • GPIO Input 4: true
          • GPIO Input 5: false
    4. Click CREATE.
    5. To generate a report on state change of one of the GPIO inputs, go to UNCONDITIONAL TRIGGERS and click CREATE UNCONDITIONAL TRIGGERS.
      • NAME: Enter a trigger name
      • ENABLE: Enable the trigger
    7. Click CREATE.
    8. Under Telemetry > MQTT, configure the connection to your MQTT server. See Configuring Telemetry for more information about MQTT settings.
