Solid Green
Solid Yellow
Solid Red
Fast Flashing Red
Slow Flashing Red
Off
Slow Flashing Green
Off
After upgrading from AirLink OS 3.0 to 3.1, the Cellular LED may flash red even though the Cellular interface is connected and passing traffic. This is caused by a radio module firmware mismatch. To restore normal LED operation, install your carrier’s radio module firmware at Admin > Radio Module Firmware Image Management > Radio Module Firmware.
Slow Flashing Green
Slow Flashing Purple
Slow Flashing Red
Off
Slow Flashing Green
Slow Flashing Red
Off
Solid Green
Fast Flashing Green
Solid Yellow
Fast Flashing Yellow
Solid Red
Fast Flashing Red
Slow Flashing Red
Off
A yellow LED chase pattern indicates an AirLink OS software update in progress.
