    Configuring VPN
    The router can act as a Virtual Private Network (VPN) device, providing enterprise VPN access to any device connected to the router even when a device has no VPN client capability on its own. The router supports up to five simultaneous IPsec VPN tunnels. The IPsec implementation is fully IKEv1 and IKEv2 compliant, and supports MOBIKE when operating over IKEv2. The AirLink OS VPN implementation also provides the option to configure IPsec tunnels to FIPS (Federal Information Processing Standards) mode.
    A note on some limitations in AirLink OS 3.1:
    • You cannot create a firewall rule that applies to outbound/inbound traffic inside an IPsec tunnel.
    • In Host-to-LAN VPN mode, you cannot use the port forwarding rules in the current release to port forward traffic over the virtual IP address.
    Client Mode and Server Mode Compared
    You can configure the XR Series router as a VPN client or VPN server. The table below outlines how the router operates in each mode.
    SERVER MODE CLIENT MODE
    Overall relationship Master – sets all details for connection, for all clients. AirLink XR Series routers running AirLink OS can support multiple clients connected simultaneously and are limited only by the throughput requirements of those clients. Slave – must match the defined details for a single connection as defined on the target server
    Tunnel specifications Server defines/sets the configuration: authentication mechanism and details, network details Client must match a configuration set on the server to which it is connecting
    Network communication Server defines what “enterprise” or central network(s) are available to remote clients, and what the expected remote network connection will look like (LAN or Host termination) Client provides the remote network segment in LAN termination and may provide the individual host address for Host termination if the server does not have the ability to assign one
    Routing Server advertises routing information to the central network to access remote clients Client provides routing for remote clients to access the central network
    Connection details Accepts or rejects tunnel connection requests Requests a tunnel connection
    IPsec Tunnel Configuration Settings
    These are the settings you’ll find in the Basic Configuration Steps described below.
    SETTING DESCRIPTION DEFAULT SETTING RANGE
    NAME Descriptive name for the tunnel n/a n/a
    MODE
    Sets Client or Server mode for VPN operation. In Server mode, the router is configured to accept incoming tunnel requests and contains all details for all possible incoming connections. In Client mode, the router must match a unique configuration contained on the server to which it is connecting.
    Client Client, Server
    LAN/HOST MODE
    • LAN: Network terminated. Use for LAN-to-LAN configuration. In a LAN-to-LAN configuration, the router provides the conduit for all host computers on the selected segment; it must match the expected network segment configured on the VPN server side.
    • HOST: Host terminated, using a Virtual IP address. Use for Host-to-LAN configuration. In a Host-to-LAN configuration, the router has a single “virtual IP address” and devices connected to the router can send to the corporate network. The corporate network devices can’t initiate connections without port forwarding rules. In that case, some VPN servers (like the Sierra Wireless ACM) have the ability to assign a virtual IP address to the router, and some VPN servers do not.
    LAN LAN, HOST
    USE DEFAULT VIRTUAL IP POOL(S) Appears when the tunnel is being configured for Server/HOST mode. Enabled Enabled, Disabled
    VIRTUAL IP ADDRESS POOL(S)
    Appears when the tunnel is being configured for Server/HOST mode. In Server/HOST mode, the router allocates virtual IPv4 IP addresses from this pool.
    Note: Ensure that the Virtual IP address pool is uniquely routable in the network topology. The IP address range cannot be part of the network on the remote (Client) end.
    10.0.3.0/24 IPv4 IP address
    Appears when the tunnel is being configured for Server/HOST mode. In Server/HOST mode, the router allocates virtual IPv6 IP addresses from this pool.
    2001:db8::3:0/24 IPv6 IP address
    CLIENT VIRTUAL IP TYPE Appears when the tunnel is being configured for Client/HOST mode. Selects how the virtual IP address is assigned. In most applications, this is left at Automatic. Automatic Automatic (requests a virtual IP address from the server), Static
    VIRTUAL IP ADDRESS
    Appears when the tunnel is being configured for Client/HOST mode. When CLIENT VIRTUAL IP TYPE is Static, this is a required field. Only one address of an IP family is allowed.
    When CLIENT VIRTUAL IP TYPE is Automatic, any IP addresses entered here are requested from the server. The server may not return the same virtual IP addresses.
    Note: Static virtual IP addresses are ignored by Sierra Wireless ACM. The ACM assigns a virtual IP address from the subnet configured in the ACM.
    n/a n/a
    IKE VERSION Sets the Internet Key Exchange (IKE) mode. The default setting of IKEv2 is required for FIPS mode and MOBIKE. You may need to select IKEv1 when the router is in Client mode and a third-party VPN appliance is not compatible with IKEv2. IKEv2 IKEv2, IKEv1
    MULTIPLE SA’s FOR IKEV2 Enables compatibility with Cisco VPNs when multiple remote subnets are used in a single child SA. If you define multiple remote subnets under REMOTE SUBNETS, enable this setting to create a separate child SA for each remote subnet. Disabled Disabled, Enabled
    MOBIKE
    In IKEv2 mode, enabling MOBIKE allows a VPN tunnel to stay connected, even if the WAN interface used by the tunnel changes. For example, the tunnel stays connected if the WAN interface changes from Ethernet to cellular.
    • MOBIKE has been tested by Sierra Wireless against Sierra Wireless’ ACM VPN server. For more information on compatibility with VPN servers, please contact Sierra Wireless.
    • After enabling MOBIKE, disable DPD because it can interfere with the fast switching provided by MOBIKE.
    • Ensure that you select more than one WAN INTERFACES, as described below.
    AUTHENTICATION TYPE Sets the authentication type/method Certificate Certificate, PSK
    CERTIFICATES
    n/a n/a
    PSK
    • Pre-shared key length: Maximum supported length is 128 characters.
    • Valid characters are: 1234567890abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ!%-~@#$^*
    • Invalid characters are: ><?&
    n/a n/a
    PEERS Required to identify the peer side of a VPN connection. This is the primary peer (see SECONDARY PEER FOR FAILOVER below) and can be an IP address or an FQDN. n/a IPv4, IPv6
    LOCAL SUBNETS Enter the local address or subnet in CIDR notation; for example, 192.168.13.0/24 n/a n/a
    REMOTE SUBNETS
    The IP address or subnet (in CIDR notation) of the device(s) connected to the remote VPN server. These addresses/subnets will be accessible from any hosts connected locally to the router. To configure a full tunnel, enter 0.0.0.0/0. To configure a split tunnel, enter the individual remote subnets.
    Note: Not available when configuring the tunnel for Server/HOST mode.
    n/a n/a
    EXEMPT SUBNETS List of Remote Addresses or subnets to be exempted. Traffic passing through the router to the IP addresses (or Fully Qualified Domain Names (FQDNs)) in this list is sent directly to the Internet (it is not sent through the IPsec VPN tunnel). n/a n/a
    LOCAL AUTHENTICATION ID You can enter the Local Authentication ID as a text string to identify the router as a VPN client. The Local Authentication ID must also be configured on the remote VPN server (the Sierra Wireless ACM, for example). Alternatively, you can leave the Local Authentication ID blank to use the default WAN IP address. The default WAN IP address would also need to be configured on the remote server/ACM. n/a n/a
    REMOTE AUTHENTICATION ID The Remote Authentication ID configures how the router recognizes incoming traffic. This setting must match the server side. n/a n/a
    WAN INTERFACES
    Select the WAN interfaces to use for this tunnel, in order of priority (first to last/left to right). The order specifies the sequence of failover if the highest-priority WAN interface loses connection.
    You can select default to have the tunnel use the default WAN zone. In that case, the default WAN priority of Ethernet, Wi-Fi and Cellular applies.
    Please note that even when default is not selected, the tunnel will use the default WAN interface if no other configured WAN interface is available.
    List of enabled WAN Interfaces (varies by router model).
    START Enable the IPsec tunnel and connect to the configured peer. Takes effect after you click CREATE. Disabled Disabled, Enabled
    DEAD PEER DETECTION (DPD)
    Dead Peer Detection (DPD) verifies the status of the active connection, and can be configured to take action if the primary/active VPN tunnel goes down.
    Possible actions when DPD detects a failed connection are: * Restart (default): The router restarts the current IPsec tunnel. * None: The router takes no action. * Failover: The router begins using the SECONDARY PEER FOR FAILOVER.
    For more information, see VPN Failover.
    Restart Restart, None, Failover
    n/a n/a
    DPD INTERVAL (SECONDS) Sets the DPD interval (in seconds). If there has been no traffic during this interval, after five retries (each with an interval of 30 seconds by default) the router takes the DPD action configured above. 30 30 - 3600
    IKE REKEY TIME (SECONDS) Sets how long the VPN tunnel is active, in seconds 7200 60 - 32000000
    IKE ENCRYPTION Sets the type and length of encryption key used to encrypt/decrypt IKE packets. IKE Encryption is the first stage of encryption. More bits in the encryption key increases the security of the traffic, but this also increases the processing load and reduces the number of simultaneous clients the router can support. aes256
    • aes256
    • aes128
    • aes128gcm16
    • aes192
    • aes192gcm16
    • aes256gcm16
    IKE INTEGRITY Sets the type and length of digest used for authentication. sha256 sha256, sha384, sha512
    IKE DIFFIE-HELLMAN GROUPS
    Use this field to select the DH (Diffie-Hellman) group pre-shared key length used for authentication. The DH group number determines the length of the key used in the key exchange process. Longer keys are more secure, but take longer to compute. Also note that both peers in the VPN exchange must use the same DH group.
    dh16 (modp4096)
    • dh16 (modp4096)
    • dh14 (modp2048)
    • dh15 (modp3072)
    • dh17 (modp6144)
    • dh18 (modp8192)
    • dh19 (ecp256)
    • dh20 (ecp384)
    • dh21 (ecp521)
    • dh26 (ecp224)
    PERFECT FORWARD SECURITY (PFS) PFS adds additional security because each session uses a unique temporary public/private key pair to generate the shared secret. One key cannot be derived from another. This ensures previous and subsequent encryption keys are secure, even if one key is compromised. Enabled Enabled, Disabled
    ESP REKEY TIME (SECONDS) Sets how long the VPN tunnel is active, in seconds 7200 60 - 32000000
    ESP ENCRYPTION Sets the type and length of encryption key used to encrypt/decrypt ESP (Encapsulating Security Payload) packets. ESP Encryption is the second stage of encryption. More bits in the encryption key increases the security of the traffic, but this also increases the processing load and reduces the number of simultaneous clients the router can support. aes256
    • aes256, aes128
    • aes128gcm16
    • aes192
    • aes192gcm16
    • aes256gcm16
    ESP INTEGRITY Sets the type and length of digest used for authentication sha256
    • sha256
    • sha384
    • sha512
    ESP DIFFIE-HELLMAN GROUPS Use this field to select the DH (Diffie-Hellman) group key length used for authentication. The DH group number determines the length of the key used in the key exchange process. Longer keys are more secure, but take longer to compute. Also note that both peers in the VPN exchange must use the same DH group. dh16 (modp4096)
    • dh16 (modp4096)
    • dh14 (modp2048)
    • dh15 (modp3072)
    • dh17 (modp6144)
    • dh18 (modp8192)
    • dh19 (ecp256)
    • dh20 (ecp384)
    • dh21 (ecp521)
    • dh26 (ecp224)
    1. Go to Networking > VPN > IPsec Tunnels.
    2. Enable IPSEC FIPS MODE, if required. When enabled, a FIPS-approved cryptographic module is used for IPsec data protection, and only FIPS-approved cryptographic algorithms are allowed for tunnel configurations. Note: FIPS is only supported for IKEv2 tunnels.
    3. Click CREATE IPSEC TUNNEL.
    4. Configure the router’s VPN mode and type of IPsec tunnel for your desired application. The following options are available:
    5. Click CREATE.
    Configuring a LAN-to-LAN tunnel in Client mode
    1. Enter a tunnel NAME.
    2. Set the router’s VPN MODE to Client.
    3. Set the LAN/HOST MODE to LAN.
    4. Select the IKE VERSION. When IKE VERSION is set to IKEv2, you can enable or disable:
      • MULTIPLE SA’S FOR IKEV2
      • MOBIKE
    5. Select the AUTHENTICATION TYPE.
      • After selecting Certificates, you must select any existing PEM Certificates on the router, or upload the certificate components to the router.
      • After selecting PSK, you must enter a text string for the pre-shared key.
    6. Enter the PEERS as one or more IPv4 or IPv6 IP addresses.
    7. Enter LOCAL SUBNETS, REMOTE SUBNETS and any EXEMPT SUBNETS.
    8. Enter LOCAL AUTHENTICATION ID and REMOTE AUTHENTICATION ID to match the credentials for your VPN server.
    9. Select the WAN INTERFACES for VPN traffic to and from the router, in order of priority.
    10. Select whether to START the tunnel when you finish configuration and click CREATE.
    11. Configure DEAD PEER DETECTION, if desired (requires you to configure the SECONDARY PEER FOR FAILOVER).
    12. Configure IKE settings.
    13. Select whether to use PERFECT FORWARD SECURITY (PFS).
    14. If PFS is enabled, configure ESP settings.
    15. Click CREATE.
    Configuring a HOST-to-LAN tunnel in Client mode
    3. Set the LAN/HOST MODE to HOST.
    4. Select the CLIENT VIRTUAL IP TYPE.
    5. Enter a VIRTUAL IP ADDRESS, if required by the CLIENT VIRTUAL IP TYPE.
    6. Select the IKE VERSION. When IKE VERSION is set to IKEv2, you can enable or disable:
      • MOBIKE
    7. Select the AUTHENTICATION TYPE.
    8. Enter the PEERS as one or more IPv4 or IPv6 IP addresses.
    9. Enter LOCAL SUBNETS, REMOTE SUBNETS and any EXEMPT SUBNETS.
    10. Enter LOCAL AUTHENTICATION ID and REMOTE AUTHENTICATION ID to match the credentials for your VPN server.
    11. Select the WAN INTERFACES for VPN traffic to and from the router, in order of priority.
    12. Select whether to START the tunnel when you finish configuration and click CREATE.
    13. Configure DEAD PEER DETECTION, if desired (requires you to configure the SECONDARY PEER FOR FAILOVER).
    14. Configure IKE settings.
    15. Select whether to use PERFECT FORWARD SECURITY (PFS).
    16. If PFS is enabled, configure ESP settings.
    17. Click CREATE.
    Configuring a LAN-to-LAN tunnel in Server mode
    2. Set the router’s VPN MODE to Server.
      • MOBIKE
    15. Click CREATE.
    Configuring a HOST-to-LAN tunnel in Server mode
    4. Enable or disable USE DEFAULT VIRTUAL IP POOL(S).
    5. Enter the VIRTUAL IP ADDRESS POOL(S) (IPv4 or IPv6), if you have disabled USE DEFAULT VIRTUAL IP POOL(S).
      • MOBIKE
    9. Enter LOCAL SUBNETS and any EXEMPT SUBNETS.
    11. Select whether to START the tunnel when you finish configuration and click CREATE.
    12. Configure DEAD PEER DETECTION, if desired (requires you to configure the SECONDARY PEER FOR FAILOVER).
    13. Configure IKE settings.
    14. Select whether to use PERFECT FORWARD SECURITY (PFS).
    15. If PFS is enabled, configure ESP settings.
    16. Click CREATE.
    VPN Failover
    To use VPN failover to help maintain your VPN connection, set DEAD PEER DETECTION (DPD) to Failover, and configure a secondary VPN peer. Dead Peer Detection (DPD) verifies the status of the active connection. For example, if the primary/active VPN goes down (that is, DPD detects that the end device is not responding), you can configure the VPN to automatically switch traffic to a backup VPN tunnel (the secondary peer).
    Multi-WAN Policies
