Automatic radio module firmware image switching (based on Carrier SIM)
For automatic Network Operator Switching to work, the router must have radio module firmware for another carrier loaded and displayed in the RADIO MODULE FIRMWARE table. The following steps describe how to ensure that the required radio module firmware is loaded onto the router.
Ensure the router is powered off.
By default, the XR90 SIM Card (slot) 1 maps to XP1 and slot 2 maps to XP2.
Power the router on.
Log in to AirLink OS.
Go to System > Admin > Radio Module Image Management.
Check if the required RMFW is showing in the Radio Module Firmware list.
If the firmware is showing and the FIRMWARE VERSION is filled in, then it will automatically switch to the correct RMFW.
If the firmware is showing, but the FIRMWARE VERSION is blank, then continue with step 7.
Update AirLink OS, as described in Updating AirLink OS Software.The software update will take 1-2 minutes, as indicated by the yellow LED chase pattern. During the update, any specified RMFW images not on the router are loaded onto the router, but are not applied to the radio module yet. The router reboots when the software update is complete.
After reboot, the router executes several checks and the RMFW image switch occurs based on the SIM that was inserted in Step 2 above, as indicated by the green LED chase pattern. The update should take about 2-5 minutes, depending on the RMFW version it is updating to.
When the update is complete, you can confirm the RMFW configuration under Status / Monitoring > Radio Module. Check that the FIRMWARE NAME, FIRMWARE VERSION, and FIRMWARE CONFIGURATION have been updated.
Example: If Bell issues a new SIM that has a different PLMN or ICCID than what is defined in the internal database, then a definition using COS to associate the new PLMN or ICCID to an existing carrier firmware is created.
In the above example,
* If a SIM with PLMN 20801 or 20820 is detected, the system will use BELL RMFW.
* If a SIM with an ICCID starting with “89330121313814” is detected, TELSTRA RMFW will be used.
Manually loading radio module firmware image on to the router
Click CREATE.
Click on the entry line to select the desired module/carrier combination from the list.
If you don’t find your desired radio module/carrier combination in the list:
a. Click on the entry line and click CREATE again.
b. Enter the new firmware name (Model ID / Firmware Name)
c. Click CREATE to create an instance with this value.
Click CREATE to add a radio module firmware entry in the table.
Click SAVE and a new row for the selected carrier appears. The FIRMWARE CONFIGURATION and FIRMWARE VERSION fields are blank.
Reboot the router to perform an Airlink OS update so that the RMFW can be retrieved and added to the router. After reboot, the router executes several checks and the RMFW image switch occurs based on the SIM that was inserted, as indicated by the green LED chase pattern. The update should take about 2-5 minutes, depending on the RMFW version it is updating to.
Optional: Manual radio module firmware image switching
This process is used when NETWORK OPERATOR SWITCHING is set to Manual so that you can manually switch the radio module firmware to a specific network operator. You can check this setting in the Hardware Interfaces > Cellular Interfaces > Cellular section.
By default on XR80: SIM Card (slot) 1 maps to the internal radio module and 2 maps to the optional XP cartridge.
By default on XR90: SIM Card (slot) 1 maps to XP1 and 2 maps to XP2.
Go to Hardware Interfaces > Cellular Interfaces.
Under Cellular > NETWORK OPERATOR SWITCHING, click Automatic to switch it to Manual.
Under SELECT NETWORK OPERATOR, select your desired carrier.
Click SAVE.
The Cellular ADAPTER STATUS indicates Initializing and then Updating Firmware within a few seconds, as indicated by the green LED chase pattern. The update should take about 2-5 minutes depending on the RMFW version it is updating to.
