| HTTP ACCESS | Configure HTTP AirLink OS WAN access | Enable, Disable, Redirect to HTTPS | Redirect to HTTPS (RECOMMENDED) |
| HTTP PORT | Configure HTTP port for Airlink OS WAN access | 1 to 65535 | 80 |
| HTTPS ACCESS | Configure HTTPS Airlink OS WAN access | Enable/Disable | Enable |
| HTTPS PORT | Configure HTTPS port for Airlink OS WAN access | 1 to 65535 | 443 |
| HTTPS CERTIFICATE | If using HTTPS, select and/or create a security certificate. See Security Certificates Documentation here on how to create a PEM certificate. For HTTPS, only a certificate and private key is required. Certificate, private key and root can be used, but root will be ignored. Root only certificates will not work. | N/A | N/A |
| HSTS | HTTP Strict Transport Security | Off/On | Off |
| SESSION IDLE TIMEOUT | The amount of idle time required before the user is automatically logged out and redirected to the login screen. | 1 to 1440 mins | 5 mins |
| MAXIMUM LOGIN ATTEMPTS | The number of failed login attempts allowed before the user account is temporarily locked for the length of time specified in the UNLOCK TIME field. Disabling this feature is not recommended. | 0(disabled) to 5 | 3 |
| UNLOCK TIME | The length of time that the user account is locked after the maximum number of failed login attempts MAXIMUM LOGIN ATTEMPTS. | 1 to 3600 seconds (1 hour) | 120 seconds (2 minutes) |
• LDAP, RADIUS, and TACACS+ are supported for AirLink OS logins, but are not supported by other AirLink router services such as Telnet, SSH, etc.
| FILE NAME | Required file name | N/A | N/A |
| SERVER | Required LDAP server IP address or resolvable domain name | N/A | N/A |
| PORT | Port number | 1 to 65535 | 389 |
| TIMEOUT |
| ENCRYPTION | Encryption type. |
start_tls |
| BASE DN | The Base DN is the path in the LDAP tree to the list of users (e.g. dc=sierrawireless,dc=com). This is where the LDAP protocol searches for a matching user to authenticate. | N/A | N/A |
| BIND | Choose how the LDAP search is done |
anonymous |
| BIND DN | This field only appears if you selected Explicit in the BIND field. The full path of the user authorized to perform requests in the LDAP | N/A | N/A |
| BIND PASSWORD | This field only appears if you selected Explicit in the BIND field. Password associated with the Bind DN | N/A | N/A |
| CONFIGURATION FILE NAME | Required configuration file name | N/A | N/A |
| SERVER | Required RADIUS server IP address or resolvable domain name | N/A | N/A |
| PORT | Port number | 1 to 65535 | 1812 |
| TIMEOUT |
| SECRET | Shared secret for configured server | N/A | N/A |
| SERVER | Required TACACS+ server IP address or resolvable domain name | N/A | N/A |
| PORT | Port number | 1 to 65535 | 49 |
| TIMEOUT |
| AUTHENTICATION PROTOCOL | Shared secret for configured server |
PAP |
| SECRET | The type of bind used for authentication | N/A | N/A |
