Device Templates are the easiest and fastest method for configuring multiple AirLink routers. AirLink OS gives you several options for creating, modifying and applying templates.
To start working with templates from AirLink OS, click the Templates icon
and select an option:
The AirLink OS screen banner changes color and states TEMPLATE mode is ON. In Template mode, check boxes appear next to text boxes, table rows, and tables to enable selection of what items will be included in the template.
To cancel template mode, click the Cancel icon
or CANCEL on the Template status bar (see below).
You may want to use this option when deploying incremental changes across multiple routers.
To create a template:
Click Create template from scratch.
You can now begin adding settings to your template.
To add a setting, select the checkbox next to the setting. The setting and its current value will be added to the template.
to delete/reset a table row (or an entire table) in the template.
If you are using ALMS, to save the template, click EXPORT.
If you are using the UI with a connected computer, the option shown is EXPORT TO FILE. There is no option to export to ALMS. Click EXPORT TO FILE, and save the JSON file to the local computer.
- For security reasons, passwords are not automatically saved to a new template. If you select any password settings, the password must be re-entered before saving the template.
You may want to use this method when you have a configured device and want to deploy additional devices “out of the box” based on the configured device.
This option creates a template using all settings that were modified by a user (different from their factory default).
Click Create template from current configuration.
When you’re ready to save the template, click EXPORT, and then EXPORT TO FILE.
Open an existing template in order to modify it by adding, removing, or updating settings and then save the template for future use.
To modify a template:
Click Modify a template from local file.
Browse to your file and then click Open. The template loads into your browser, and Template mode is ON.
To apply a template:
Click Apply a template.
Browse to your template file, and then click Open.
A confirmation message appears.
On the status bar, click > to view which settings the template will update.
