The AirLink router is equipped with a USB 3.1 Type-C Gen 1 (SuperSpeed 5 Gbps) port. This page describes how to:
To use the USB interface in WAN mode, click and leave LAN SEGMENT blank.
The XR system in the examples below has the default LAN address set to 192.168.80.0/24 and IPv6 is enabled.
Your Windows 10 computer indicates that it is setting up a virtual COM port, and confirms when the installation is complete. You can verify the status in the Notification Center.
Go to Windows Updates and check for Optional Updates and select the Acer Incorporated – Other Hardware – USB Ethernet/RNDIS Gadget. (This may not be available if your computer uses an internal corporate Windows update server.)
Note: The USB Ethernet/RNDIS Gadget can also be downloaded from Microsoft.
After this initial setup, you can use the Device Manager to verify the presence of the “USB Ethernet RNDIS Gadget” in the Network Adapters list.
To confirm that the network is available and the adapter has been assigned address(es), open a Command prompt window and type ipconfig.
In System Preferences, open the Network center and verify that the RNDIS/Ethernet Gadget appears and is connected.
