    Enabling ALMS Advanced Mobility Reporting
    AirLink XR80 and XR90 routers, with their vehicle telemetry capability and inertial sensors, will support all features of AMR.
    1. Under Services > Location > General, ensure that GNSS is enabled.
    2. Under Services > Telemetry > General, enable SERVICE.
    3. Under Services > Telemetry > Vehicle:
      • Enable DATA COLLECTION.
      • Set MODE OF OPERATION to Active when Ignition is ON.
      • Set VEHICLE IGNITION WIRING to Connected AirLink gateway Ignition Sense input line.
    4. Under MCU > Power Management, configure the ignition SHUTDOWN DELAY to be at least 30 seconds.
      • In the POWER SOURCES table, click Edit ( ) on the row for Source > Ignition.
      • Set the SHUTDOWN DELAY to at least 30 seconds.
      • Click UPDATE.
