The AirLink XR80 has four Ethernet ports, labeled 1 to 3, with the fourth port reserved for RS-232 use. By default, all Ethernet ports are configured as LAN interfaces; however, it is possible to configure ports as WAN interfaces (see below).
When WAN AUTO DETECT is enabled for an Ethernet port, the system may internally modify the DHCP settings for that port. If you disable WAN AUTO DETECT on that same Ethernet port, you should verify the WAN configuration settings (under Networking > General > WAN) and modify them if required.
You can configure an Ethernet interface for WAN mode by leaving the LAN Segment field empty.
