AirLink XR80 and XR90 routers, with their vehicle telemetry capability and inertial sensors, will support all features of AMR.
Under Services > Telemetry > Vehicle:
Under MCU > Power Management, configure the ignition SHUTDOWN DELAY to be at least 30 seconds.
