    Configuring Telemetry
    General
    Vehicle Settings
    DATA COLLECTION Enables or disables data collection On/Off On
    MODE OF OPERATION Configures when data collection will be active
    • Active always (Ignition status ignored)
    • Active when Ignition is ON
    VEHICLE IGNITION WIRING This setting determines which input line the router monitors for ignition status. Select the option that matches how the vehicle ignition line has been connected to the router.
    VEHICLE IGNITION STATUS Current vehicle ignition status. Read only. On/Off N/A
    Vehicle Odometer
    Odometer is not a standard OBD-II data point. On heavy duty vehicles and some selected light duty vehicles, it can be read from the CANBUS. However when it is not available, it can be derived from speed and distrance travelled. Setting the derived odometer configures the starting point from which to calculate further distance from.
    SET DERIVED ODOMETER (KM) Sets the derived odometer with a starting value from which to calculate further distance from. 0 to 1000000 0
    ENTERED AT Date and time that the SET DERIVED ODOMETER was updated. Read only. N/A N/A
    CURRENT ODOMETER (KM) Current physical odometer reading. Read only. N/A N/A
    CURRENT ODOMETER TIMESTAMP Date and time that the CURRENT ODOMETER was read. Read only. N/A N/A
    AMR Reports
    ENABLE When enabled, the full telemetry data set is sent to AirVantage so that all Advanced Mobility Reports (AMR) can be viewed. Only displays when Telemetry is enabled. On/Off On
    Custom Reports
    REPORTS
    SETTING DESCRIPTION
    REPORT MODE
    • ALMS
    • MQTT
    • ALMS and MQTT
    GENERATE THIS REPORT AT POWER ON Report that will be generated when the device powers on. Note: Only one report can be selected.
    GENERATE THIS REPORT AT POWER OFF Report that will be generated when the device powers off. Note: Only one report can be selected and in situations where there is an abrupt power disconnect a report may not be generated.
    SETTING DESCRIPTION
    GENERATE THIS REPORT… List of reports that have been defined. nly one report can be selected.
    EVERY …(SECONDS) Number of seconds between each report interval
    SETTING DESCRIPTION
    ENABLE When enabled, the configured report will be generated at each data sample. Default is On. ptions are On/Off.
    AT EVERY SAMPLE OF…
    Options are:
    • GPIO Input Cumulative
    • WAN Ready
    • Ignition Status
    • Primary WAN
    • Primary GPIO Input
    • GPIO Input 2
    • GPIO Input 3
    • GPIO Input 4
    • GPIO Input 5
    Example 2 : WAN Ready
    • Time A: Cellular is UP. XP Cellular is UP.
    • Time B: Cellular is UP. XP Cellular is DOWN.
    No sample is generated because the WAN connectivity for the device is still UP through Cellular.
    • Time B: Cellular is DOWN. XP Cellular is DOWN.
    Example 3 : Ignition Status
    • Time A: Ignition is DOWN.
    • Time B: Ignition is UP.
    • Time C: Ignition is DOWN.
    Example 4 : Primary WAN
    • Time A: Cellular is UP and designated PRIMARY WAN. XP Cellular is also UP.
    • Time B: Cellular goes down. The PRIMARY WAN designation is re-evaluated to see if Cellular is still the PRIMARY WAN, and it is not. Cellular – Down. XP Cellular – New PRIMARY WAN.
    SETTING DESCRIPTION
    Options are:
    • Absolute Throttle Postion (%)
    • Ambient Air Temp (degrees C)
    • Battery Voltage (V)
    • Calc Engine Load (%)
    • Distance Traveled with MIL on (km)
    • Driver Seatbelt
    • Engine Coolant Temp (degrees C)
    • Engine Fuel Rate (mL/h)
    • Engine Oil Temp (degrees C)
    • Engine RPM
    • Fuel Level input (%)
    • GNSS DR Calibration
    • GNSS Heading (degrees)
    • GNSS Trip Odometer (m)
    • GPIO Input 2
    • GPIO Input 3
    • GPIO Input 4
    • GPIO Input 5
    • Hybrid/EV battery - remaining charge (%)
    • Ignition Status
    • MAF Sensor air flow rate (mg/s)
    • Manifold Surface Temp (degrees C)
    • Odometer (km)
    • PTO Status
    • Run time since DTCs cleared (minutes)
    • Run time with MIL on (minutes)
    • Time since Engine Start (seconds)
    • Transmission Fluid Temp (degrees C)
    • Trip Fuel (liters)
    • Trip Odometer (km)
    • Vehicle Speed (km/h)
    • WAN ready
    SETTING DESCRIPTION
    Options are:
    • Driver Seatbelt
    • Engine RPM
    • GPIO Input 2
    • GPIO Input 3
    • GPIO Input 4
    • GPIO Input 5
    • Ignition Status
    • Odometer (km)
    • PTO Status
    • WAN ready
    <RELATIONAL OPERATOR>
    Options are
    • > (greater than)
    • >= (greater than or equal)
    • == (equal)
    • <= (less than or equal)
    • < (less than)
    • != (not equal)
    Example : LEVEL Trigger
    SETTING DESCRIPTION
    Options are:
    • Driver Seatbelt
    • Engine RPM
    • GPIO Input 2
    • GPIO Input 3
    • GPIO Input 4
    • GPIO Input 5
    • Ignition Status
    • Odometer (km)
    • PTO Status
    • WAN ready
    Options are
    • > (greater than)
    • == (equal)
    • < (less than)
    • != (not equal)
    Example : EDGE Trigger
    Vehicle Behavior Reports
    ENABLE Enables vehicle behavior reports On/Off On
    REPORT MODE Destination of where reports will be sent to. The MQTT configuration will only display if the REPORT MODE is set to an MQTT option.
    • ALMS
    • MQTT
    • ALMS and MQTT]
    ALMS
    EXCESSIVE ACCELERATION THRESHOLD(MILLIG) Maximum acceleration allowed before notification is triggered 100 to 1000 250
    EXCESSIVE ACCELERATION QUALIFICATION TIME Length of time in milliseconds, over which acceleration data is collected and analyzed to determine whether an excessive acceleration event has occurred 250 to 1000 500
    EXCESSIVE BRAKING THRESHOLD(MILLIG) Maximum braking allowed before notification is triggered 100 to 1000 350
    EXCESSIVE BRAKING QUALIFICATION TIME Length of time in milliseconds, over which braking data is collected and analyzed to determine whether an excessive braking event has occurred 250 to 1000 500
    EXCESSIVE CORNERING THRESHOLD(MILLIG) Maximum cornering allowed before notification is triggered 100 to 1000 350
    EXCESSIVE CORNERING QUALIFICATION TIME Length of time in milliseconds, over which cornering data is collected and analyzed to determine whether an excessive cornering event has occurred 250 to 1000 500
    SUM THRESHOLD(MILLIG) Vector sum of 3 dimensions(forward/backward, left/right, up/down) 100 to 2000 800
    SUM QUALIFICATION TIME Amount of time that harsh movement was detected. In milliseconds 250 to 1000 250
    MQTT
    CLIENT ID Unique vehicle id
    N/A
    • None
    • Username and Password
    None
    TOPIC
    6Q1099009902AC24/test {
      “atp.ser” :
            “t”: 1693258321.3640001,
            “v” : “6Q1099009902AC24”
            “ts” : 1693268920.464
    0 : At most one-time delivery. Your data can be lost. No retransmission outside of TCP.
    1 : At least one-time delivery. Your data will be retransmitted if needed. The message can be received more than once.
    2 : Exactly one-time delivery. The message will be delivered exactly once but the communication overhead is high (multiple acknowledgement messages).
    0
    • ATP FORMAT - ATP FORMAT will use an atp prefix on the data sent to the MQTT broker, for example : atp.GLON
    • NON-ATP FORMAT : uses least amount of data over the air, for example : GLON
    ATP FORMAT
    • Individual Timestamp - Timestamp of each sample collected.
    • Report Timestamp - Timestamp of when the report is generated. Least amount of data used.
