reset using factory defaults
reset using a custom template
| HOLD BUTTON FOR ... | ACTION | POWER LED BEHAVIOR |
| < 5 seconds | Release to reboot the router | Fast flashing green |
| 5 to 20 seconds | Release to reset to the RESET CONFIGURATION TYPE state | Fast flashing red |
| 20 to 40 seconds | Release to reset to factory defaults | Fast flashing yellow |
| Over 40 seconds | Release to cancel reset | Fast flashing yellow and red |
RESET CONFIGURATION TYPE: This setting is used to specify what type of reset configuration will be used when resetting the router configuration.
Templates created from different software versions or different hardware cannot be applied to the router. “Version mismatch” and “Product mismatch” alerts will indicate incompatibility. If the CURRENT TEMPLATE is incompatible, it will be automatically deleted.
Click RESET SETTINGS to reset the router. A confirmation screen will appear.
Click CANCEL to cancel the reset, or click RESET SETTINGS to reset.
