| WI-FI INTERFACE | MODE | ANTENNA BANK |
| Wi-Fi A 5GHz |
Access Point (Default) |
Always uses Antenna Bank A (i.e. “Wi-Fi A” connectors). |
| Wi-Fi AP 2.4GHz | Access Point (Default) |
Uses Antenna Bank A or B. (A — “Wi-Fi A”, B — “Wi-Fi B”) |
| Wi-Fi B 5GHz |
Client (Default) |
Always uses Antenna Bank B (i.e. “Wi-Fi B” connectors). |
| Wi-Fi Client 2.4GHz | Client (Default) | Uses Antenna Bank A or B. (A — “Wi-Fi A”, B — “Wi-Fi B”) |
The REGION field is the regulatory domain that the router Wi-Fi is using. It is determined by using either the Global Navigation Satellite System (GNSS) sensors in the router, or by the Mobile Country Code (MCC) or Mobile Network Code (MNC) received from the carrier and received directly by the receiver on the device. The router automatically loads the operating frequencies for that regulatory region on each Wi-Fi radio interface in the software and enables 802.11d for broadcasting the newly obtained country information. If the router is not able to determine the region, it uses a default region setting. For more information on supported channels, please refer to the Wi-Fi specifications in the AirLink XR80/XR90 Hardware User Guide .
For more information on supported channels, refer to the Wi-Fi specifications in the AirLink XR80/XR90 Hardware User Guide .
If the AirLink router cannot determine the region, the default region setting for that router variant determines whether the PLACEMENT switch appears.
For example, if an AirLink router EMEA variant cannot determine the region, the REGION appears as “Unknown (restricted)” and the PLACEMENT switch appears, with Indoor as the default.
NOTES:
- The region and, if applicable, PLACEMENT option applies to both AP and Client mode. In Client mode, the router will only be able to connect using the applicable channels.
- Available channels may differ, depending on the region’s regulatory requirements.
- Enabling DFS Channels will make DFS-specific channels available to both AP and Client mode regardless of the region and, if applicable, PLACEMENT option.
For details on how your router is determining its region, go to Status > Services > Geolocation.
In the Physical field, select the network standard to use.
In the Channel Bandwidth field, select the bandwidth to use (up to 80 MHz). Each 20 MHz of bandwidth corresponds to 1 channel (i.e., 1 channel = 20 MHz, 4 channels = 80 MHz).
Select the MIMO (Multiple Input/Multiple Output) configuration for your installation to optimize throughput and signal quality. Each Wi-Fi antenna bank can have up to 4 antennas connected. Select a non-default setting for an access point if you discovered problems with legacy equipment, have fewer than the maximum number of antennas connected, or to improve the XR90’s thermal performance.
- Enabling DFS allows for more 5GHz channels, but may result in delayed connectivity at boot and in the presence of radar.
- The DFS Channels setting applies to both AP and Client mode. In Client mode, the router will only be able to connect using the available channels.
Best Practice recommendation: If the 2.4GHz and 5GHz AP(s) are configured on different LAN segments, use different SSIDs and security passphrases to make sure DHCP renews IP addresses when switching between the APs.
For all security modes except OPEN and WPA2-Enterprise, enter a SECURITY PASSPHRASE of at least 8 characters.
- Wi-Fi A 5GHz in AP mode supports up to 128 clients (includes clients connected to up to two additional 5GHz SSIDs)
- Wi-Fi AP 2.4GHz supports up to 64 clients (includes clients connected to up to two additional 2.4GHz SSIDs)
- Wi-Fi B 5GHz in AP mode supports 64 clients (includes clients connected to up to two additional 5GHz SSIDs)
For example (using the Wi-Fi A 5GHz radio in the figure below, which is capable of supporting up to 128 clients):
Configured Maximum Total Allowed Wi-Fi A 5GHz connected Wi-Fi A 5GHz SSID 1 connected Wi-Fi A 5GHz SSID 2 connected Available Wi-Fi A 5GHz = 128
Wi-Fi A 5GHz SSID 1 = 128
Wi-Fi A 5GHz SSID 2 = 128128 50 46 0 32 across all three SSIDs Wi-Fi A 5GHz = 30
Wi-Fi A 5GHz SSID 1 = 20
Wi-Fi A 5GHz SSID 2 = 1060 25 20 5 10 across Wi-Fi A 5GHz and Wi-Fi A 5GHz SSID 2
(Wi-Fi 5GHz A SSID 1 is at max.)
Up to two additional SSIDs can be enabled for each of the access point interfaces (i.e., two for Wi-Fi A 5GHz, two for Wi-Fi AP 2.4GHz, and two for Wi-Fi B 5GHz).
To configure this feature:
On Status > Dashboard, the LAN dashboard shows you the Wi-Fi LAN interfaces and the LAN segments they use. A blue Access Point icon (
Additionally, you can go to Status > System > Wi-Fi to view detailed Wi-Fi Access Point status, including the active channel and connected stations (clients).
Tip: Hover the pointer on a scanned SSID to view the channel, BSSID and RSSI for each band.
To use a scanned SSID:
In the SCANNED SSIDS table, click + to add the desired SSID to the SELECTED SSIDS table.
Note: The router supports up to 6 SSIDs in the SELECTED SSIDS table.
In Edit SSID, add the credentials required by the SSID’s security mode, along with any other optional settings.
Click UPDATE.
To create an SSID manually:
| SETTING | DESCRIPTION |
| TYPE | Root Certificate |
| NAME | Required name identifying the certificate |
| ROOT CERTIFICATE | Click to upload the root certificate file |
| TYPE | Certificate |
| PRIVATE KEY | Click to upload the private key |
On Status > Dashboard, the WAN dashboard shows you the Wi-Fi WAN interfaces. A grey Wi-Fi icon (
Additionally, you can go to Status > System > Wi-Fi to view detailed Wi-Fi Client status, including bit rate and the active channel.
