To reduce the router’s power consumption, you can turn off the LEDs by going to System > LEDs > LED Powersaver Mode and clicking ENABLE. For more information, see LEDs.
Solid Green
Solid Yellow
Solid Red
Fast Flashing Red
Slow Flashing Red
Off
Slow Flashing Green
Slow Flashing Purple
Off
| RSSI | RSSI | RSRP | SNR | |
Slow Flashing Green
Slow Flashing Red
Off
Slow Flashing Green
Slow Flashing Red
Off
Solid Green
Fast Flashing Green
Solid Yellow
Fast Flashing Yellow
Solid Red
Note: If the router is in standby mode, the Power LED will be solid red only if the AirLink OS Standby LED setting is enabled (System > Power Management > Standby Mode), otherwise the LED will be Off. (By default, the setting is enabled.)
Fast Flashing Red
Slow Flashing Red
Off
A yellow LED chase pattern indicates a software update in progress (a XR router firmware update, radio module firmware update, etc.)
