The purpose of the uploadlog tool is to upload log files from ALEOS devices to the AMM so these log files are visible from the Browse log files menu. This tool is useful because logs from ALEOS devices are not uploaded in real time.
In AMM 2.16.1 and below, ALEOS logs are uploaded to the AMM in plain text.
From AMM 2.16.2 onwards, support for a management tunnel for ALEOS devices was added.
In order to enable secure encrypted uploads, the uploadlog app must be updated on the devices.
uploadlog 1.0.2 (available in AMM 2.16.2) allows logs to be sent over the management tunnel if it is established. If it is not available, the logs are sent in plain text.
uploadlog 1.0.3 (available in AMM 2.17.2+) added the ability (enabled by default) to inhibit the transfer of logs outside the management tunnel. If the management tunnel is down, the ALEOS logs will be held at the device, subject to a maximum accumulation of log data (oldest data will be deleted first to keep data storage under the threshold) until the management tunnel is re-established. The configuration setting is set to secureTransfer=true by default.
It is highly recommended that this setting be left enabled, otherwise device logs will be sent in clear text instead of going through a secure channel. If the devices are not upgraded to uploadlog 1.0.3, then they will continue to use the currently installed version of uploadlog and will not enforce the new secure transfer option using the management tunnel.
Obtaining and Installing the Tool
To obtain the tool:
Additional Configuration Recommendations
There are three settings related to this tool in the uploadlogconfig file. To access this file:
The following settings in this file should be set as described here:
Note: The setting secureTransfer should be disabled, if uploadlog 1.0.3 is used but the management tunnel is not being used (e.g. with older AMM versions or closed secure networks), otherwise log transfer will not be possible.
