Multi-factor authentication(MFA) has been implemented on the AMM starting from version 2.17.2. The 2-factor authentication will have username and password as the first authentication, and a one time pass code (OTP) as the second authentication. There are two methods available for the second authentication.
The requirements for using MFA are as follows:
If email MFA authentication is to be used:
If TOTP authentication is to be used:
The limitations are as follows:
Multi-factor authentication cannot be setup on LDAP users.
Only one method of MFA can be setup per user.
Any authenticator app that is TOTP-compliant can be used. There are many authenticator apps available for mobile phones, however, users should choose an authenticator app carefully, as not all apps will properly safeguard the user’s TOTP secret. Google Authenticator and Microsoft Authenticator are the two common authenticator apps that have been tested with the AMM and were selected because of the reputation of the companies who made them. Users should exercise common online safety measures when selecting an authenticator application.
If the user deletes the authenticator app from their device or loses their TOTP secret, then they will need to contact their administrator. Refer to Resetting TOTP secret for more information.
To set the MFA at the user level to use Email, follow the steps below.
To set the MFA at the user level to use Authenticator App, follow the steps below.
A group can be configured to use multi-factor authentication. When setting the MFA in a group, the change will cascade down to all the sub-groups and users. If any other method had been previously set, it will be overridden. When the user next logs into the AMM, they will be prompted to setup the MFA method that the administrator has set.
If some users are not to inherit the change in MFA method, then the Use group authentication settings for this user must be unchecked in the profile of the user, before the change is done in the group.
If some subgroups are not to inherit the change, then the administrator will need to set the MFA method individually on those subgroups, before the change is done in the group.
To set the MFA for a group, follow the steps below.
The regular user would not normally have read/write access to Authentication under their user privileges and therefore would not be able to reset their TOTP secret. The administrator would have to reset the TOTP secret using the following steps.
If the user has read/write access to both AMM and Authentication under their user privilege settings, then the user can setup their MFA method themselves. Users with AMM and Authentication privileges are normally admin-like users.
To setup MFA method,
Subsequent logins to the AMM will prompt the user for the verification code from the authenticator app.
After the AMM has authenticated the username and password, it will ask for a verification code and wait for the user to input one. The user must submit a verification code within the configured timeout threshold (default 2 minutes). If the page times out, the user will be redirected back to the login page with an error code: Correct verification code was not entered before timeout.
The timeout threshold can be configured in the web.xml file with the following entry:
  <context-param>
    <param-name>inmotion.mfa.timeout.inseconds<param-name>
    <param-value>120<param-value>
  <context-param>
If the user enters the wrong verification code, the AMM will allow the user to retry for a configured maximum number of retries (default is 3). If the user enters the incorrect code more than the configured number of retries, then the user will be redirected back to the login page with an error code: Too many failed attempts with incorrect verification code.
The retry threshold can be configured in the web.xml file with the following entry:
  <context-param>
    <param-name>inmotion.mfa.maximum.retrys<param-name>
    <param-value>3<param-value>
  <context-param>
In addition to existing user activity entries on login, the following MFA user activity logs are created and visible in Admin > User Activity.
| Event | Message |
| User pre-authenticated with password, awaiting verification code | Login pre-authenticated, await verification. MFA method: Email|Authenticator App |
| MFA login successful | Login verified. MFA method: Email|Authenticator App |
| MFA login encountered an error | Login error. MFA method: Email|Authenticator App, MFA error: Error message |
The following table lists common errors messages.
| Error Message | Description |
| Correct verification code was not entered before timeout. | User did not enter the correct verification code before the timeout threshold expired. |
| Incorrect verification code. | User did not enter the correct verification code. |
| Too many failed attempts with incorrect verification code. | User entered the incorrect verification code too many times. |
