To effectively manage changes on an ALEOS device, you need to know how it was configured, and when it was configured. The ALEOS status page and the AMM dashboard are able to easily identify this information about the ALEOS device.
ALEOS devices can be configured using three methods.
On the AMM, there are several stats that can be setup as thresholds on the dashboard to easily identify configuration changes. For more information on how to setup a threshold, refer to Adding a New Threshold
Template Deploy from AMM
When a template is deployed from the AMM to an ALEOS device, the management template stats will show the name of the last template uploaded, the date and time when it happened, and if the ALEOS device is in sync with the template on the AMM. The stats used on the AMM to report this are :
Template Apply from ACEmanager
When a template is applied from ACEmanager to an ALEOS device, it will show the name of the template uploaded, the date and time it happened, and if the ALEOS device is in sync with the template. The stats used on the AMM to report this are :
Manual Change using ACEmanager
If the ACEmanager is used for a manual change, then the stat LastConfigurationChange is updated with the date/time and ConfigTemplateInSync and ACEmanagerTemplateInSync are updated to No.
AMM Dashboard showing Template Stats setup as Thresholds
In the above figure, a template was applied from ACEmanager on Aug 6, 2:25:11PM. However it is not In Sync, so the ALEOS device is not using that template.
On Aug 18 8:34:12AM, the AMM deployed a template to the device. It is In Sync, so the ALEOS device is using the AMM template.
The ALEOS device records the time stamp for applying the template first. Then changes are made as per the template. The LastConfigChange stat is updated after the last configuration change is completed.
From the LastConfigChange field, the last recorded configuration change was at Aug 24 11:13:56AM.
ACEmanager showing Template Information
Additional Information:
