Performing a nightly backup of a server is essential for safeguarding data and ensuring a quick recovery in the event of an unexpected diaster.
As the backups will contain secrets and other security information, they should be maintained at the same level of security as the AMM login itself.
The duration of backups can significantly differ based on your configuration. To ensure a smooth backup process, it is advisable to schedule it at a time when users are not active, allowing ample time for the backup operation to complete.
To ensure the integrity of the data, the following procedure to backup an AMM should be followed.
There are numerous data backup methods available with two common backup methods outlined below. Nevertheless, it is advisable to assess your own specific requirements to determine the most suitable backup method.
The following example creates a snapshot of the entire system using a block level or system level backup. If you need assistance with a backupdatadisk.sh script, please contact Technical Support.
#!/bin/bash
set -ue
touch /var/log/inmotion/backupdatadisk.log
# stop AMM and database services
/usr/sbin/ammctl stop &> /dev/null
/bin/systemctl stop mysqld &> /dev/null
sync
echo 1 > /proc/sys/vm/drop_caches
/usr/sbin/ammctl status >> /var/log/inmotion/backupdatadisk.log
echo "`date +%Y%m%d:%H:%M:%S` :Core services stopped prior to snapshot" >> /var/log/inmotion/backupdatadisk.log
## Run Snapshot and cleanup. backupdatadisk.sh in this example would contain the commands to perform the backup.
/opt/inmotiontechnology/scripts/hosted/backupdatadisk.sh
# Restart services
/usr/sbin/ammctl start &> /dev/null
echo "`date +%Y%m%d:%H:%M:%S` :Services restarted after snapshot" >> /var/log/inmotion/backupdatadisk.log
The following example will backup only AMM data files. Several prerequisites must be put in place for this backup script to function properly.
#!/bin/bash
set -ue
REMOTE=10.0.0.1 # change 10.0.0.1 to IP address of remote server
sshopts="-oStrictHostKeyChecking=no -oPasswordAuthentication=no -oUserKnownHostsFile=/dev/null -oLogLevel=ERROR"
ssh $sshopts root@$REMOTE mkdir -p /mnt/BACKUP/home/inmotion \
/mnt/BACKUP/var/lib \
/mnt/BACKUP/etc \
/mnt/BACKUP/opt/inmotiontechnology \
/mnt/BACKUP/mnt/amm_data/opt/tomcat/webapps \
/mnt/BACKUP/mnt/amm_data/etc/openvpnmgr
echo "$(date +%Y%m%d:%H:%M:%S) Backup start" >> /var/log/inmotion/backup.log
srcdirs="/home/inmotion/ftp /home/inmotion/MHS_certs /home/inmotion/MHS_config /home/inmotion/MHS_software /home/inmotion/MHS_api_usage_logs /home/inmotion/MHS_donetask /home/inmotion/MHS_reports"
rsync -a -e "ssh $sshopts" --delete $srcdirs root@$REMOTE:/mnt/BACKUP/home/inmotion/
rsync -a -e "ssh $sshopts" --delete /mnt/amm_data/var/lib/mysql /mnt/amm_data/var/lib/tftpboot root@$REMOTE:/mnt/BACKUP/var/lib/
rsync -a -e "ssh $sshopts" --delete /etc/openvpnmgr root@$REMOTE:/mnt/BACKUP/etc
rsync -a -e "ssh $sshopts" --delete /mnt/amm_data/etc/openvpnmgr/ root@$REMOTE:/mnt/BACKUP/mnt/amm_data/etc/openvpnmgr/
rsync -a -e "ssh $sshopts" --delete /mnt/amm_data/opt/inmotion root@$REMOTE:/mnt/BACKUP/opt/
rsync -a -e "ssh $sshopts" --delete /mnt/amm_data/opt/tomcat/webapps/inmotion root@$REMOTE:/mnt/BACKUP/mnt/amm_data/opt/tomcat/webapps/
rsync -a -e "ssh $sshopts" --delete /mnt/amm_data/opt/inmotiontechnology/certs root@$REMOTE:/mnt/BACKUP/mnt/amm_data/opt/inmotiontechnology/
echo "$(date +%Y%m%d:%H:%M:%S) Backup complete" >> /var/log/inmotion/backup.log
