The steps below describe how to use the AMM’s Gateways and Deploy screens in conjunction with ACEmanager, to update configuration parameters on a fleet of ALEOS devices. This procedure allows for parameters to be configured uniquely for each device, so that a mass configuration update can be performed where each device will have unique parameter values for individual MSCIIDs.
- This feature is available AMM 2.16 and above.
- This feature requires knowledge about creating and updating AMM CSV import files. For additional information about CSV import files see the AMM Operation and Configuration Guide: Appendix A.4 - Multiple Device Import CSV.
- Not all valid MSCIID values can be set using this feature. Only Configuration values can be set. Any non-configuration values will be ignored by this process.
- Using the CSV upload procedure to manipulate ALEOS settings as described in the steps below, is intended to be used for configuring device-specific variables and is not intended to do complete configurations.
a. Open ACEmanager for an ALEOS device in a browser.
b. Right click on the input field of the parameter that you want to update and select the browser’s menu item which allows you to inspect the element (e.g. “Inspect”).
Selecting the inspection menu item for an ALEOS parameter.
c. Locate the Name attribute in the raw HTML that is displayed. The value for this attribute is the MSCIID:
Locating the Name attribute. The value is the MSCIID.
The figure below shows another example of locating an MSCIID for a element, this time, from the Device Status Screen in ACEmanager:
Example of Locating an MSCIID for an element from the Device Status Screen.
Create or Update an AMM CSV import file for configuring multiple devices as per the options below, using the MSCIID(s) obtained in Step 1. For additional information see Multiple Device Import CSV.
ID | Name | Groups | Vehicle Type | Customer | Location | Contact | Notes | MSCIID=5024 | MSCIID=5 |
N12341 | “Joe - MP70 II” | Mixed Bag | Default Vehicle Group>SUV | Customer1 | Office | Joe | Main device | 8 | test1234 |
Note: leaving a cell blank for a given row means that the value won’t be updated for device specified on that row.
Navigate to the Admin->Gateways menu in the AMM. Note that if you’re planning to update MSCIID parameters related to security (e.g. passwords), first ensure that you are logged in to the AMM using HTTPS, otherwise updates for such parameters will fail.
Click the Upload button:
Upload button on the Gateways screen.
Select the CSV file that was prepared in Step 2, select Modify for Gateways which already exist in AMM, and select Deploy configuration to gateways:
Preparing the Gateway List Import dialog.
Select the Config->Deploy->Deploy menu in the AMM to display the Deploy screen.
Click the refresh button and verify that the State column for the device is set indicates Out of sync-local:
The Refresh button and the device's State.
The State changes to Config Confirmed after the ALEOS device checks in and the configuration change is completed.
Note: * the ALEOS heartbeat field show in the AMM is not an indicator of when the device will check in next. ALEOS devices have an independent check-in frequency. * the device(s) may need to be rebooted in order for the change(s) to apply (e.g. when changing the M3DA Protocol Password).
Wait until the State changes to Config Confirmed.
Open ACEmanager for the device and verify that the MSCIID parameter(s)
Using ACEmanager to verify that the MSCIID value was successfully updated on the ALEOS device.
have been changed on the ALEOS device:
The following table provides the ID values and descriptions for common MSCIID’s that you may want to configure. Note that these exact values must be entered as input.
Common MSCIIDs
Field | MSCIID | Notes and Comments |
ACEmanager Password | 5003 | |
Name | 5023 | Requires AMM 2.16.2+. This will populate the device’s name in the AM/AMM if it hasn’t been manually set in the AM/AMM or if the Name field wasn’t specified when the device was imported using the Multiple Device Import CSV. |
Device Initiated Interval (minutes) | 5024 | AM/AMM Heartbeat (check-in frequency) |
Server URL | 5027 | URL of the management server (AM or AMM) in your environment |
M3DA Protocol Password | 10255 | |
ACEmanager Remote Access | 1173 | Set ACEmanager remote access to Disabled, HTTPS Only, or Both HTTP and HTTPS |
ACEmanager HTTP Port | 1150 | Default value is 9191 |
ACEmanager HTTPS Port | 1172 | Default Value is 9443 |
Location TAIP ID | 1300 | Set a unique TAIP ID for the device, if using TAIP for GPS data |
LAN Ethernet Device IP | 1084 | |
LAN Ethernet Starting IP | 1137 | |
LAN Ethernet Ending IP | 1138 | |
RX Diversity | 2152 | Enable/Disable |
Setting for Band (WAN/Cellular->Cellular->Band Settings) | 2057 | Requires code to be set: 00=All bands; 01=Europe 3G; 02=North America 3G; 03=Europe; 04=North America; 05=WCDMA All; 06=LTE All |
User Entered APN (WAN/Cellular -> Cellular -> SIM Slot 1 Configuration) | 10710 | |
Pre-shared Key 1 (VPN -> VPN1) | 3155 | Assumes IPSec Tunnel is configured. |
Local Address (VPN -> VPN1) | 3167 | Assumes IPSec Tunnel is configured. |
Local Address – Netmask (VPN -> VPN1) | 3168 | Assumes IPSec Tunnel is configured. |
Device Name (Services - > Dynamic DNS) | 1154 | Assumes IP Manager is configured. |
Management Tunnel | 10033 | Disables the management tunnel. |
Distribute Management Tunnels | 10034 | Distributes management tunnels over multiple openvpn instances for a large fleet. |
