WP76xx Firmware Release 13.1/13.2/13.3 Components
Jan 02, 2020 - Author: Sierra Wireless - Version 13.1/13.2/13.3 - 5985 Views
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 13.1, 13.2 and 13.3 components and how to download it on your product.
WP76xx Firmware Release 13.1/13.2/13.3 combined image
SWI9X07Y_02.28.03.03 / 002.068_000
Download R13.1/R13.2
SWI9X07Y_02.28.03.05 / 002.073_000 Download R13.3
SWI9X07Y_02.28.03.01 / 002.064_000
Modem Firmware (AT&T)
SWI9X07Y_02.28.03.01 / 002.071_000
Modem Firmware (Docomo)
SWI9X07Y_02.28.03.05 / 001.024_000 Download
Modem Firmware (KDDI)
SWI9X07Y_02.28.03.05 / 001.026_000 Download
Modem Firmware (Softbank)
SWI9X07Y_02.28.03.05 / 001.028_000 Download
Modem Firmware (Telstra)
SWI9X07Y_02.28.03.05 / 001.058_000 Download
Modem Firmware (Telus)
SWI9X07Y_02.28.03.01 / 001.000_000 Download
Modem Firmware (Verizon)
SWI9X07Y_02.28.03.04 / 002.075_000
Modem Firmware (Sierra Wireless— GCF)
SWI9X07Y_02.28.03.03 / 001.026_000
SWI9X07Y_02.28.03.05 / 001.032_000 Download R13.3
002.011
Download R13.1
Download R13.2
Download R13.3
19.02.0
 Legato Source Release #
19.02.0 Source
 R13.1 (Based on Kernel 3.18.131 and Yocto 2.5)
SWI9X07Y_02.28.03.03 Source
 R13.2 (Based on Kernel 3.18.131 and Yocto 2.5)
SWI9X07Y_02.28.03.04 Source
32-bit ToolChain
 R13.3 (Based on Kernel 3.18.131 and Yocto 2.5)
SWI9X07Y_02.28.03.05 Source
32-bit ToolChain
©2026 All rights reserved
